Converter Box I have just bought a converter box for our tv, which is antenna only. While the picture is beautiful we still cannot get some chanels, we've tried everything, please help.
    Genius:
  • Televison & ... Master
  • 1,673 Answers
You should verify if the channels you want are actualy being recieved by your antenna. Do you have any neighbors with the same setup? There may also be some compatiblity issues with the TV set to the converter.
Jerry G.
Posted on May 25, 2008
Im trying to hook tv up with reg antenna and basic chanels. Tv scans chanel but doesent come thru
Do you have a converter box? You need a device called a "Digital To Analog" converter.
May 19, 2017 | Televison & Video
I just bought a converter box for a Mitsubishi screen tv cause I don't have cable but I'm not getting picture or audio n the converter says boot what does that mean
manufacturer & model number of converter box? do you have an outdoor (aerial) or indoor antenna connected to the converter box?
Oct 04, 2015 | Mitsubishi Televison & Video
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Converter Box Problem
If you are receiving digital signal and channel is fuzzy, something wrong. Only Analog signal is fuzzy. With Digital it is great picture or nothing. For channel 6, check to see if they are broadcasting in digital yet. If they are not, this is why you are not getting a signal. If they are broadcasting in digital, then you need a stronger antenna.
May 27, 2009 | Insignia Digital-to-Analog Converter for...
Converter boxes hook up
u need a stronger antena , best check without the converter box and see if u get chanels , if u do hookup the antena to the converter box then to the tv and do the scan again , move the antena to diferent places
May 01, 2009 | Funai Trutech 13" TV
Dtv converter box, no PS2
you need to hook up the ps2 directly to the tv not the converter box the converter box is only for digital Chanel's that will go off air on june 12 but if you have cable or satellite then you don't need a converter box this is only for free Chanel's with they don't requires subscription to cable or satellite your playstation should work with out the box try to hook it up directly to the tv not the box
Apr 28, 2009 | Video Game Consoles & Games
Hook up analog vcr to hd tv
You must have a converter box for the tv and for the vcr. Set the vcr to receive chanel 3 and set the converter box to the digital chanel you want to record. Put a splitter on the antenae out and route one to the tv converter box and one to the vcr converter box. GOOD TO GO.
Apr 11, 2009 | Sanyo Televison & Video
We just converted our analog and get a bad picture
I would think it is wise to try another converter box. That is the only way to know for sure. There is also a possiblity that the reception where you are located is very poor.
Jerry G.
Feb 09, 2009 | Insignia Digital-to-Analog Converter for...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
