Question about HP Pavilion Dv3-1075us Notebook
Bsod 0x00000034 - HP Pavilion Dv3-1075us Notebook
    President:
  • 2,291 Answers
Check the size of Random Access Memory (RAM) in your computer. Its small size could be the reason for this problem as many of today's software need large amount of memory to operate in smooth manner. Additional RAM will also increase the efficiency of your computing particularly for gaming.
• Excessive use of computer or a malfunctioning cooling system can make computer/laptop overheated. Whenever system is heated, its efficiency will go down. BSOD is one possible consequence of over heated system. Keep fan of your computer in fully functional mode.
• Registry is the most vital part of Win 7. Corrupt registry is the biggest reason for BSOD in Win 7. One way is to clean registry manually but manual tricks could wreck your system completely if you are not a top notch computer expert. More appropriate way is to buy a good registry cleaner reginout and PC optimizer
Posted on Sep 30, 2010
  • me me Nov 02, 2010
    The CACHE_MANAGER bug check has a value of 0x00000034. This indicates that a problem occurred in the file system's cache manager.
    Check your hard drive for errors as a problematic hardrive can cause this issue. help to run the harddrive checks can be found herehttp://www.mypchealth.co.uk/GuideTests.p...
    List of bug check codes for blue screens of death can be found herehttp://www.mypchealth.co.uk/Win7Codes.ph...
I keep getting the bsod while installing windows xp
loads1900
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Mar 29, 2010 | Acer Computers & Internet
STOP: 0x00000034 blue screen error... says to disable bios memory options such as caching or shadowing but I can't access windows it keeps restarting and going back to blue screen..... safe mode dont work,...
This is a cache manager error or a missing DLL file error. This might have heppend as a result of some hardware of software changes that you might have made recently. You can either install the removed drivers once again or need to run a repair reinstall of windows to get the curropt dll files working again.
http://www.jj54.com/Fix-Error-Number/0x0000/
Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
Mar 19, 2010 | Microsoft Windows XP Professional With...
Getting stop: 0x00000034 blue screen error need help!
This is a memorey cache manager error or a missing or curropt dll file error. This might have resulted due to some recent changes that you have made to any of your hardwares or softwares. The options to get them rectified would be to install the corect drivers back or do a repair reinstall of windows.
Mar 19, 2010 | HP Pavilion Dv3-1075us Notebook
System BSODs when trying to boot from USB
fbeondo
Thanks
Issken
Jan 29, 2010 | CMS BounceBack Professional (096122800758)...
Blue screen and the charger works sometimes
blue screen aka bsod. when you get this bsod it will show you stop error code. you need to get the code to identify the exact issue you're having. If the bsod occures after the dell logo issue might be the video card or memory. if the bsod occures after windows logo then if might be caused by a corrupted windows updates or windows system file corruption. if the bsod occured after dell logo then check your memory if you have 2 ram modules try to remove 1 ram first then try booting your system using only 1 ram, try to swap and isolate reseat and teach eash slot on each ram module. if bsod occures after windows logo then try to run a test for your hard drive Fn+Power. If no errors it might be windows file corruption which needs to be restored or re-installing OS.
Oct 02, 2009 | Dell Latitude D510 Notebook
Bsod on Startup
streylem
Thanks
Issken
Sep 26, 2009 | EA - Electronic Arts Need For Speed:...
A8N32 BSOD PROBLEM
I had a similar problem with this board after putting in a new sata drive I got Bsod as windows xp started loading.
There is some kind of conflict with SP3, Sata and usb.
The solution for me was to boot while having a 4GB usb drive pugged in. It starts up fine now. If I remove the usb drive it bsod´s again.
Dec 14, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Bsod 0xdeaddead. restart and when it wants to.
No programs added. Microsoft updates can crash to BSOD 0xdeaddead 0x00000000 0x00000000 0x00000000 0x00000000. When I restart it gos to bsod above. Will be working on a file and it will crash to the bsod above. Not every Microsoft update will crash in the process of installing but some have. No new hardware or software has been added for sometime now. Streets and Trips has been loaded and taken off several times because it will not run with out a startup error. Everything other than that works fine.
Aug 27, 2008 | Computers & Internet
BSOD
YES there is a way to get past BSOD after the software update fails....
May 02, 2008 | Magellan Roadmate 760 GPS Receiver
Frequent bsod problem
Please Post information about the BSOD for help, codes, messages, anything is helpful.
Sep 20, 2007 | Microsoft Windows XP Professional With...
HP Pavilion Dv3-1075us Notebook Logo
368 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
