Question about Toshiba Satellite A100-S8111TD Notebook
My Toshiba satellite P100 keeps turning itself off and back on constantly. We have reformatted it completely, have cleaned it, have replaced the RAM and nothing has fixed it. It is driving us all crazy. Help to solve this would be greatly appreciated. Thank you Chris Hayden
  • 6,831 Answers
Hello Chris
Firstly, let me ask you a couple of questions.
Do you hear the cooling fan spin very fast?
Have you had any problems with overheating in the past?
Let me know, i will gladly assist.
Kind regards
Andrea
Posted on Sep 30, 2010
It will not power with battery
the battery charger circuit is short circuit, therefore need to repair or test the battery is ok
Aug 13, 2017 | Toshiba Satellite P100 Notebook
Toshiba satellite pro p100 screen problem
The LCD can be replaced. The part is around $50-$75 I believe. It can be tricky to replace, but if you take your time, you can save money by doing it yourself. The screen sounds cracked or broken, and black & white will not work either.
good luck
Mar 19, 2013 | Toshiba Satellite P100 Series / Satellite...
How to Reformat a Toshiba Laptop p100-160 without the disc
Hi to reset your Toshiba back to factory settings you just need to restart the system while restarting press 0. If i did not work you factory image is bad the only thing you can do is to get a reset disc from them. Thanks
Feb 17, 2011 | Toshiba Satellite A100-S8111TD Notebook
How do I reformat my Toshiba Satellite P100?
put the recovery cd in reboot and tap F2 then change the boot order to cd/dvd rom first boot.save and exit then reboot. or recover from computer tap F11.
hope this helps.
Apr 30, 2010 | Toshiba Satellite A100-S8111TD Notebook
Need to know how to dismantle Toshiba Satellite P100 to clean and check heatsink and fans, unit keeps overheating and shutting down thanks gene
Here is Toshiba Satellite P105 (which is the same as P100) disassembly guide.
Just follow instructions by scrolling down, then go to page 2, 3, ...
Jun 10, 2009 | Toshiba Satellite P100 Notebook
LCD Screen turned opaque at two places, I see two white opaque lines 3 inches wide one on left side of screen and other in the middle
Yes you are correct. I would say 95% of the time, you will need a LCD screen replacement. Also be sure to disconnect and reconnect the lcd cables, at the motherboard and behind the lcd itself, just to make sure the cables aren't making bad connection.
I have provided you a link to MANY lcd screen for your laptop on EBAY.
http://computers.search.ebay.com/Satellite-P100_Screens-LCD-Panels_W0QQcatrefZC6QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQdfspZ32QQfromZR2QQfsooZ2QQfsopZ32QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZ31569QQsargnZQ2d1QQsaslcZ2QQsbrftogZ1QQsofocusZbs
Hope this helps you. Please rate my solution.
May 16, 2009 | Toshiba Satellite P100 Notebook
How can i recover my laptop to factory settings?
Applicable Models: Satellite L15-S104, L15-S1041, L20-S310TD, L20-SP231, L25-S119, L25-S1194, L25-S1217, L25-S1213, L25-S1215, L25-S1216, L25-S1196, L25-S1211, L25-S1214, L25-S1212, L25-S121, L25-S1193, L25-S1192, L25-S1195, L35-SP1011, L35-S2366, L35-S2316, L35-S2206, L35-S2194, L35-S2174, L35-S2171, L35-S2161, L35-S2151, L35-S1054, P100-ST7111, P100-ST9212, P100-ST9712, P100-ST9742, P100-ST9772, P100-ST9762, P100-ST9752, P100-ST1072, P100-ST9732, P100-ST1071, P100-ST9412, P100-ST9612, P100-ST9012, P100-ST7211, P105-S921, P105-S931, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6034, P105-S6024, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6074, P105-S6054, P105-S9312, P105-S6014, P105-S6002, P105-S6004, P105-S6012 << hideThe printed instructions included with the Recovery and Applications/Drivers Media disc are correct for most computer models. For some models, however -- including those listed above -- booting from the Recovery disc requires pressing the F12 key, rather than the 'C' key. The instructions below are correct for these models.
CAUTION: The Recovery process reformats the computer's hard disk drive, which completely erases its contents -- including all applications, all documents, and all other data stored on the drive. Be sure to back up your documents and other data before following the instructions below.
Follow these steps to erase the current contents of the hard disk drive and to re-install all of the software that was installed on the computer when it was manufactured:
1. With the computer on, insert the first Recovery disc into the optical drive.
2. Shut down the computer (click the Start button, click Shut Down, select Shut Down, click OK).
3. Press the computer's power button to turn the computer on, and then immediately press and hold the F12 key. Release the F12 key when the menu of boot options appears.
4. Use the arrow keys to navigate to the CD/DVD option. Press the Enter key to select it.
The computer will restart, and will boot from the Recovery disc.
5. Follow the instructions on the screen to start the Recovery process.
CAUTION: Once the Recovery process has begun, do not interrupt it.
The computer's hard drive will be formatted, erasing its contents. All of the software that was installed on the computer when it was manufactured will then be re-installed.
6. Once the Recovery process is complete, remove the Recovery disc, and press any key to restart the computer.
- mc/wa
Jan 27, 2009 | Toshiba Satellite P105-S6207 Laptop
Laptop works fine until the screen turns complete black...
Well you can look if you pluged cable into GeForce not into motherplate second you can try it on another laptop if it works well you must repair your computer
Dec 31, 2008 | Toshiba Satellite P100 Notebook
Toshiba P105 S6104
Hi Ed;
This is issue has resolution as it has been published on Toshiba's Official Support Website. It seems you need to go to an Authorized Toshiba Center. They have a special tool to re-flash your BIOS and it will resolve the issue. I am adding the original text and link for the solution below
Good Luck
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1827224xml&sliceId=&dialogID=24612375&stateId=1%200%2024610494
New BIOS fixes incorrect power-on password prompt Document ID: 98082329 Posted Date: 08/21/07 Last Updated: 08/21/07 Category: ACPI, BIOS, Password Distribution: Public Applicable Models: Satellite P100-ST7111, P100-ST7211, P100-ST9212, P100-ST9612, P100-ST9412, P100-ST1071, P100-ST9732, P100-ST1072, P100-ST9762, P100-ST9772, P100-ST9752, P100-ST9742, P100-ST9712, P100-ST9012, P105-S921, P105-S9312, P105-S6074, P105-S6034, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6134, P105-S6024, P105-S6054, P105-S6014, P105-S6004, P105-S6012, P105-S6002, P105-S931 << hide Use of any software made available for download from this system constitutes your acceptance of the Export Control Terms and the terms in the Toshiba end-user license agreement both of which you can view before downloading any such software.
Issue
The computer models listed above may display a "Password =" prompt when the computer is turned on, even though no power-on password has been set. If this happens, there is no password that will satisfy the password request. If the computer is turned off and back on again, it is very likely that the same password prompt will appear. The computer will be unusable until this problem is fixed.
If the problem has not happened yet, you can prevent it from happening in the future by upgrading the BIOS to the newest version.
The occurrence of this problem on any particular computer is unpredictable -- it may never happen, but it could happen any time that the computer is turned on. If this problem does occur, it will be necessary to send the computer to a Toshiba Authorized Service Provider, who will fix the problem at no charge to you.
Resolution
If this problem has not yet occurred on your computer, then click the following link to download and install BIOS version 4.00. This BIOS displays a power-on password prompt only when a power-on password has actually been set via the BIOS Setup program.
You may also browse for a newer version of the computer's BIOS at pcsupport.toshiba.com.
For more help, see Support Bulletin 98081213 Obtaining downloads and support docs from the Toshiba Support website.
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com.
Jan 11, 2008 | Toshiba Satellite P105-S6104 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
108 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
