Question about Canon imageRUNNER 400S Copier
Ir 405 copier code as displayed e005. but what is problem i am changed web roller but still e005
    New Friend:
E005
Posted on Nov 11, 2013
  • 4,323 Answers
Hi
Error E005 means the fuser cleaner roller has run out & may need a replacement. If the error is false it will disappear by following the reset procedure. To clear this error code press * 2 and 8 * in that 2&8 are pressed simultaneously. Go to the web counter and clear the counter back to Zero (0). Machine will now restart your machine & error code will disappear. If this doesn't help then try clearing both web counters in service mode, COUNTER>MISC>FIX-WEB> and COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode FUNCTION>CLEAR>ERR>. Hope this helps... Daniel
Posted on Sep 30, 2010
I have the e005 code, where are the upper and lower fuser roller located in a ir 400s?
A E005 error code means that the cleaning web needs to be replaced & the web counter needs to be rest. The fuser unit is on the left side of the copier, the side that the paper comes out... Good Luck
Jan 22, 2011 | Canon imageRUNNER 400S Copier
E005 code
A E005 means that the upper fusing roller cleaning web has run out and it needs to be replaced & the web counter needs to be reset.
May 29, 2010 | Canon NP 6085 Copier
E005 - which part(s) to replace?
E005 code refer to fixing web roller.After replacing the web be sure to reset the two web counter in service mode Copier-Counter- Misc-Fix_-Web and Copier=Counter-DRBL-1=FX Web.
Nov 17, 2009 | Canon ImageRUNNER 330s Copier
How do i reser error code e005 0100
How to clear fixing web counter after replacement of fixing web roller: E005 Error Code
[ Case in the field ] Field Remedy
Execute the following service mode items.
1. COPIER > COUNTER > MISC > FIX-WEB
2. COPIER > COUNTER > DRBL-1 > FX-WEB
Sep 04, 2009 | Canon CLC 1180 Copier
Canon CLC800 error E005, How do I reset?
I have the same difficulties
please help me if you got solution
my E mail is:mabdi6325@gmail.com
Jul 11, 2009 | Office Equipment & Supplies
Remove canon copier problem e005 np6330 on display
You will need to replace the cleaning web that rides above the upper fixing roller. There is a sensor that reads the amount of web left... Good Luck
Jun 11, 2009 | Canon imageRUNNER C3200 Copier
How do I fix a broken fixing film
You don't have to fix the fusing film on a Canon IR-400, it dose not have one. It has a upper and lower fixing rollers. But it does have a Cleaning Web and it would show on the display that the web needs to be replaced or it codes out with a E005. Afixxing film is on a IR-200 & IR-210 & IR-2200 & NP- 1625 series
Nov 17, 2008 | Canon imageRUNNER 400S Copier
E 005
A E005 is saying the cleaning web needs to be replaced or the web counter needs to be reset...If the cleaning web is out it will cause more damage to your upper fixing roller
Jul 28, 2008 | Canon NP 6050 Copier
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
667 people viewed this question
old marine
old marine
