Question about Nintendo DS Lite Console
Ds lite top screen flashes white when turned on then shuts off
SOURCE: Display screen on DS Lite
I had this same problem on my Lite earlier this year.  It was still under warranty, so I sent it in to Nintendo repair, who replaced the hinge assembly.  Based on the symptom and the repair, I suspect it's caused by a loose/damaged ribbon cable between the upper screen and the rest of the Lite.
I'd be leery of trying to fix it yourself (I've worked on similar problems in laptops), but if your Lite is out of warranty, you might try one of the third-party repair services.  Depending on whether the ribbon cable is damaged or just loose, they may not even need any replacement parts.
Posted on Oct 18, 2007
  • 19 Answers
SOURCE: my nintendo ds lite top screen isn't working properly
Top LCD's flex cable that passes through right-hand hinge into bottom part of case will be damaged or not properly seated in its connector socket.
Posted on Jan 01, 2008
SOURCE: Top Screen Replacement of DS Lite
there is a video tutorial at http://www.maxconsole.net/?mode=news&newsid=11484
which tells you how to disassemble the ds lite
Posted on Jan 18, 2008
JULIANFIX
  • 975 Answers
SOURCE: DS Lite Turns off when moving top screen.
ITS AN INTERMITTENT CONTACT with the ribbon belt that connects from the main unit to the upper screen , I believe you need to take the DS for an authorized repair shop, but before doing anything , give a call to a tech support at NINTENDO , THEY would gladly help you out and inform you whats the next step , hope this helps , AJ , in case you dont have the LINK, let me give it to you : http://www.nintendo.com/consumer/ ,
hope this helps AJ
Posted on May 10, 2008
  • 119 Answers
SOURCE: red ds lite screen
When the screen has a red hue there are two possibilities:
The screen is broken or the connector has moved.
The "water" is in fact the liquid crystal diplay that is broken.
Replacing the screen will cost about € 20
Here you can find the instructions:
http://www.instructables.com/id/Repairing-a-Nintendo-DS-Lite/
Please rate!
Posted on Jan 07, 2009
Screen flashes white then goes black
Sounds like a ribbon cable to the top screen maybe damaged. Upon startup, the ds does a systems check, any kind of failure e.g. a ribbon cable or a faulty screen would cause the console to shut down again. Presuming everything else works charging etc this is most likely to be the problem.
Sep 10, 2012 | Nintendo DS Lite Console
My son's DS lite stopped working while he was playing. Tried charging...no good. Bought new battery...no good. When turning on the charge light turns green then the bottom screen flashes white (like it...
Hello there! First of all let me tell you that your nintendo ds can be repaired and it is not trash... what you need is to get the bottom screen to be repaired ....you can do it sending it to the nintendo repair shop or by doing it yourself by following this youtube guide http://www.youtube.com/user/nintendorepair.
Sep 21, 2011 | Nintendo DS Lite Console
My problem is that every time I turn on my ds lite the white light flashes and then it shuts off and it's fully charged.
Hi the solution to your problem is
A failed top screen the ribbon had gone
The green light comes on screen flashes an then goes off
I repair nintendo ds lites in the uk
So can sort you out for a reasonable price
Apr 23, 2011 | Nintendo DS Lite Console
Screen goes white on power on and then shuts down power
This is basically due to a faulty screen. Depending on which screen flashes white when you first turn the DS on, this tells you which screen is faulty. If the bottom screen flashes then it is the top screen that is faulty. If the top screen flashes then it is the bottom screen that is faulty. Screens are fairly easy to fit although the top screen is the harder out of the two, you can buy them off of ebay for around £10 and if you google DS screen replacement there are some good guides out there showing you how to do it.
Hope this helps
Jan 29, 2011 | Nintendo DS Lite Console
My ds lite won't turn on both fuses are good the top screen was broke so I tried another screen I had that dident work. So I put the old one back on and now the ds wont turn on .The green lite flashes then...
It's all to do with the top screen... What happens is that when you turn the DS lite on it performs a quick check on the screens to make sure they are connected properly, if one or both are not connected properly then the unit will shut down.
The flashing of the screen shows you that that particular screen is fine whereas the one that does nothing is not connected properly, either through a loose connection or faulty screen/ ribbon.
Your best bet is to buy a new top screen (I usually get mine from ebay for around £10-£12) and fit it. That should sort out your issue.
Any further problems or questions feel free to message me via my profile page.
Regards,
SOD69
Feb 22, 2010 | Nintendo DS Lite Console
My ds will not turn on
It sounds like one of you're screens has broken. What you have discribed is generally what happens one either the top or bottom LCD screen has broken.
If it is the top screen the bottom screen will flash for 1/2 a second and the DS turns off.
If it is the bottom screen the DS should still turn on but with no reaction from the screens. (the Ds will shut down immediatley after turning on)
Sep 17, 2009 | Nintendo DS Lite Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
My ds turns on, then a couple of seconds later, it turns off
if the bottom screen flashes it's the top lcd screen (yes the top) is broken
Aug 02, 2008 | Nintendo DS Lite Console
Ds lite
Try charging it.
Dec 23, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
196 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
