Question about Brother XL-2230 Mechanical Sewing Machine
Bobbin winder won't spin Cannot load bobbin because the spindle does not revolve otherwise machine sews well.
  • Anonymous Mar 15, 2014
    after use the blade would not dislodge from the spindle it revolves on. I love this little machine and would like to hear that it can be fixed.
  • 17,130 Answers
Can be dirt or particles that have made it stuck with friction and so a resetting /overhauling with good oiling, degresing will resolve the matter, provided there is wearing off in the drive.
First use a degreasing spray before you can disemble.
Posted on Sep 30, 2010
  • pjpebbles Apr 14, 2011
    Hi, how do you actually do this though...degrease before disassembling the machine. I tried to disassemble it tonight and couldn't even pull it apart after removing all the screws? I can hear that it needs some lubrication in there somewhere but how to I get to it. Are there online instructions somewhere for this.
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Can I fix a broken bobbin winder on my Janome sewing machine by myself?
If your bobbin winder is malfunctioning and you are unable to resolve the issue, for ~$25 you can purchase a stand-alone bobbin winder at the local fabric store (JoAnns or Hancocks) or even online (Amazon).
Oct 30, 2015 | Janome Sewing Machines
I have a brother ES-2000 sewing machine. My bobbin winder stopped working due to disintegrated bobbin winder tire. I just replaced the tire. When I try to wind a bobbin, it spins for a few seconds and...
you may need to take it in for repair. Try spinning your winder spindle. It is possible the spindle has seized and the motor is trying to work to hard to spin it. If it is seized you could try some natural lubricator or WD But you would need to make sure you don't spray any on any other parts other then the metal spindle itself....Hope this helps
Machine Tech
Oct 15, 2013 | Sewing Machines
Singer curvy
Three possible causes: 1.Bobbin not push fully down the bobbin winder spindle
2.Need to push bobbin winder spindle to the left before you can wind the bobbin
3.The bobbin winder spindle rubber ring has worn out. This will need a local technician to fix it.
Aug 16, 2013 | Sewing Machines
Bobbin stuck on bobbin winder spindle
you might have to use some force but not enough to break
the bobbin winder spindle. it's also possible that there is something
wrong with the bobbin for it to get stuck on the bobbin winder spindle
like that.
Nov 29, 2012 | White Sewing 2037 Mechanical Sewing...
Sewing machine Singer Advance 7422, I try to fill a bobbin on the top of my machine. I put the bobbin in position and the shaft will not turn. The machine is treaded correctly and put in the right...
some machine, you have to push the bobbin winder spindle to the
right so that it will wind the bobbin, I have to on mine.
but if you've already done that then the machine needs to be checked
to see what wrong with the bobbin winder spindle
Aug 21, 2012 | Singer 7422
The bobbin shaft will not spin
make sure the bobbin winder spindle has been pushed to the right
if you've done that, & it doens't wind the bobbin then the machine
will need to be checked
The bobbin on my kenmore sewing machine model 158.15720 won't spin to wind the bobbin. I oiled it but it didn't help. The belt is a little loose. Could replacing it help?
most machines will have a rubber o ring as part of the bobbin winding mechanism, when you engage the bobbin winder, this o-ring will move over against the main engine drive wheel and this then makes the bobbin spindle turn. So yes, you may need to replace the rubber o-ring, they can perish and wear. Called Bobbin Winder Tyre, you could try www.sewingpartsonline.com, they have loads of Kenmore models listed but can't see yours. However, if you email them, they should be able to advise what part number it is. If you start by opening up the machine case and take a look at the bobbin winder area first, you may find this rubber has split or perished.
Oct 11, 2011 | Elna 2007 Mechanical Sewing Machine
Bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
Sep 01, 2009 | Necchi 3537 Mechanical Sewing Machine
Brother XL-2230 Mechanical Sewing Machine Logo
415 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
