Question about Apple iPhone Smartphone
Camera shutter not opening - Apple iPhone Smartphone
  • Apple Master
  • 17,129 Answers
Might be the drive or the control, try a hard reset with the battery taken off for 30 minutes. try also to reset , if the fault wont help then you might need to go on for help only if the camera is most important as the cost needs to be estimated.
Possible that a software reinstallation might resolve .
Posted on Sep 30, 2010
My Nikon coolpix l820 the screen doesn't work on camera setting but does on the video camera setting
hi,
when the still camera works the shutter of the aperture and iris is opening for a limited time, if it opens without limit the excess light will enter in and the result will be blurry picture, if the shutter is not opening the picture will be dark. in movie mode the shutter will be always in opened state, so I think there may be fault in shutter.
in some cases a slight jerk giving to cam when you depressing the snap button will reset the shutter and will work normally.
Nov 24, 2015 | Nikon COOLPIX Cameras
Shutter won't open
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 25, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
The pictures are coming out black.
Sounds like the film is not exposed, shutter not opening. If possible fire the shutter with the camera open/back off, pointed towards a light source, if the shutter opens you will see the light thru the shutter/lens. If no light is seen then the shutter is stuck.
Oct 28, 2010 | Polaroid MiniPortrait 203 Instant Camera
Shutter won't open/blaack when you look through lens
Your shutter may be stuck open... this will give the appearance of the shutter not opening as well as no image when you look through the viewfinder.
Open the back of the camera, as if you were replacing the film, and look to see if the shutter is open. If it is, you can probably see light coming through the lens when looking from the back of the camera.
If this is the case, you will need to find out why the shutter is stuck open.
Some cameras use a battery to activate the shutter, some cameras have a "bulb" setting that keeps the shutter open for long exposures.
Whatever you do, do NOT force the shutter... I might jiggle it a little bit to see if it will close, but I wouldn't recommend more than a slight jiggle.
While you have camera open, inspect the mirror. If the shutter is closed but the mirror is stuck "up" (to allow light to reach the shutter/firm), there is a chance that you would not be able to activate the shutter.
Aug 31, 2010 | Pentax Program Plus 35mm SLR Camera
When i take it to develop film cames back the shutter not closing or opening ? on pic onit at all
I would check the shutter by:
1) open the film door
2) While looking into the camera, press the shutter button.
The shutter should open and then close. If the shutter doesn't open and then close, it could be stuck and my require professional help.
Jul 01, 2010 | Nikon N75 with 28-80 lens 35mm Film Camera
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
My digital ixus 70 camera.my camera screen is black when i open my camera,snap shot is also black,plz help
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Jan 23, 2010 | Canon Cameras
Power Shot A620 Canon 7.1 mega pixel 3 years
Dec 30, 2009 | Canon PowerShot A620 Digital Camera
When i turn on the camera the shutter closes, when I turn it off, the shutter opens
I dropped the camera and now the shutter opens when turning off & closes when I open the camera. But when it is open, the shutter will open a bit making it impossible to take pictures. What should I do or where do I take it for repairs?
Tks, Ruth
Sep 11, 2009 | Sanyo VPC-S500 Digital Camera
My camera takes black pictures and the shutter won't open when I take them.
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Apple iPhone Smartphone Logo
148 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
