Receiving a wide band in scanned and copied documents. the band exists before document is printed. Documents printed directly from on-line sources or software are clear. Printer/Scanner/Copier Model CX4200
  • Anonymous May 11, 2009
    I can't open epson scan
  • 300 Answers
Clean the scanner glass, clean the scanner
If you are unsure how, download the cx4300 reference guide from the link below (yours is discontinued) click on scanner then maintenance -
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cwi+TwtWff3Y5azz8r1PYz8&tc=5
Posted on May 25, 2008
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
When we feed documents through the document feeder the copies come out blurred. We do not have that problem when we place the documents directly on the glass plate.
When paper is fed through the document feeder it scans the whole page on a little strip of glass about an inch wide and about 12 inches long. That strip has dirt on it that needs cleaned off. Lay the bad copy on the glass (face up) and you can line it up with that little glass and see where the lines match up. Clean that little glass with alcohol or glass cleaner and it will be fixed :)
Mar 31, 2015 | Office Equipment & Supplies
I have a fax-jx200 it shows ;auto print off . so there are faxes in memery how do i get to turn off auto print.
Press [ON/OFF] to select <auto print off>
The fax starts receiving documents to the memory
To cancel press [ON/OFF] again.
Oct 20, 2011 | Canon FAX-JX200
Ricoh MP 2500 copied documents have a line across top of page when fed into document feeder when document is scanned the line appears on the scanned version as well. line does not appear on...
Clean the scanner strip glass. This is the thinner strip of glass that runs from front to back right next to the large glass. This glass is only used when scanning/copying using the document feeder. The line you are seeing is because something has become stuck to the glass so when the documents are fed over the strip of glass, the scanner reads the stationary spot of debris as a solid line. Clean the glass very well using a cloth and some glass cleaner. I have seen something get under the glass as well but this is very rare. Rest assured tho that the line is being caused by something on this strip of glass.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 21, 2010 | Office Equipment & Supplies
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
Lines of copies utilizing automatic feeder
look to the side of your big glass and you'll see a piece of glass about 1.5" wide. thats the galss that is used for scanning from the feeder. theres got to be something on that glass. possibly white-out or even a small speck of toner can cause that. look closely.
hth,
razors
Mar 16, 2009 | Brother MFC-9440CN Laser Printer
One inch black band with copying
I think the scanner has crud or dust on the reader. You likely want a "pro" to clean it.
Jan 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
118 people viewed this question
jasbo
jasbo
