Question about Refrigerators
Psd243lgrq: cannot remove blue bypass cap after 6 months
  • avtuley Mar 15, 2009
    I purchased a Maytag Performa refrigerator with the blue bypass still on. When I try to remove, it stays put and does not budge.
    purchased a used maytag performa, psd262lheb, and it still has a blue bypass cap that I can't remove.
Turn off the water supply to the refrigerator and then drain some of the chilled water. This will relieve the pressure in the water line. Then push in on the cap and give it a quarter-turn to release it. You need to push pretty hard, but not too hard or you'll break it. If you are ALMOST to the point that you feel like you would want to grunt to push any harder, then you are in the zone.
Posted on Dec 21, 2009
How do I remove a refrigerator water filter bypass cap?
It should twist about a quarter-turn counterclockwise - like from the 3:00 position to the 12:00 position - then pull straight out. It fits the housing exactly the same way as the filter fits it.
Jul 25, 2014 | Fisher and Paykel Refrigerators
Where is the water filter on my whirlpool model gx2fhdxvy09
Water Filtration System
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Do not use with water that is microbiologically unsafe or
of unknown quality without adequate disinfection before
or after the system. Systems certified for cyst reduction
may be used on disinfected waters that may contain
filterable cysts.
IMPORTANT: The disposable water filter should be replaced at
least every 6 months. If the water flow to the water dispenser or
ice maker decreases noticeably before 6 months have passed,
replace the water filter more often.
Replacing the Water Filter
To purchase replacement water filters, model UKF8001AXX-750
or model UKF8001AXX-200, contact your dealer or call
1-800-253-1301 U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. See "Water and Ice Dispenser(s)."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
User Manual=> HERE I am here should you need me, Thanks John Tripp Appliance 911
Apr 16, 2014 | Admiral 26 cu. ft. Side-By-Side...
Can't get blue bypass cap off to put water filter
are you sure what you're turning is a bypass cap? KitchenAids don't usually have bypass caps.
If it is a bypass cap though, make sure you're turning to the left. It could be tougher because it's under pressure, so turn the water off going to the fridge and run the water out the dispenser if there is any.
Mar 09, 2012 | KitchenAid Refrigerators
Water and Ice have tasted like **** since we got the refrigerator (about 1 year ago) I believe the soultion is bypass the storage tank, but I can't find it..
When the Ice Smells
1. Replace water filters every 6 months to avoid musty odors from getting into your ice. If you don't replace the filters, they become clogged with the chemicals they have been removing from the water. In addition to smelly ice, you may see a drop in water pressure if you have a water dispenser, and possibly a decrease in ice cube size.
2. Remove the cap from the new filter.
3. Place the cartridge inside the holder, and twist to the right.
When the ice smells...water & ice have tasted like ***** also.
Good day : )
Jun 21, 2011 | Refrigerators
LCD model viewSonic vx2235wm 6 months out of warranty, When powered up, the backlight will flash, but then screen is dark. The blue light at the bottom is on and Vista recognizes the monitor. Sometimes, I...
Are you sure about no bad caps? The top of the caps have to be completely flat, and bad caps can also look normal but can have high ESR, you will need meter that can read ESR of the caps.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Post the pictures of the board and caps.
Sep 05, 2010 | ViewSonic VX2235wm LCD Monitor
Want to know when and how to replace water filter on a ge side by side refrig
The water filter status light or indicator, present on some models, will help you know when to change your water filter. The light, or indicator, is located either on the temperature control panel in the refrigerator compartment or on the dispenser control panel on the freezer door.
The indicator will be one of two styles.
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red or when water flow to your water dispenser or ice maker noticeably decreases.
If the indicator resembles a stack of bars, the bar height will decrease and the status display will change from "Good" to "Order." This tells you that it is almost time to change the filter. Replace the water filter cartridge when the water filter status display changes to "Replace" or when water flow to your water dispenser or ice maker noticeably decreases.
If a filter status light/indicator is not present, the filter should be changed at least once every 6 months. Your filter may need to be replaced more frequently depending on your usage and water quality.
If the water flow to the water dispenser or ice maker noticeably decreases before 6 months have passed, you may need to replace the water filter cartridge more often. Decreased water flow is a sign that the filter is clogged and needs to be replaced.
If the filter is clogged and you are not able to immediately replace it, remove the filter so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing or low ice production. However, in order to have filtered water, you will need to install a new filter.
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
The filter should be replaced at least every 6 months depending on your water quality and usage.
Step 2
Press the eject button to release the filter from the base grille.
Step 3
Pull the filter straight out.
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing
Hope this helpout in changing the water filter......
Aug 10, 2010 | GE Refrigerators
I can't get the bypass cap off to replace the
I just got my whirlpool fridge and I'm having the exact same problem! The blue cap appears stuck and I'm afraid I'll break it if I force it with a tool. Please post a solution if you get one - I'll do the same. Thanks.
Oct 23, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
I have a 97 suburban that keeps burning the cap and rotor, When I replace them it runs great for about a month and then it starts missing and then within about 6 months it burns out and wont run. Thanks,...
Ive seen caps develop tracking, but cannot remember ever seeing one burn out...What does it look like when that happens? Also, I'll assume it is burning for now...have you tried a high quality cap & rotor like the blue ones made by Standard Motor Products? (they have a high dilectric# and can handle voltage far in excess of what a stock coil can produce.
Jun 16, 2009 | 1994 Chevrolet S-10 Blazer
Blue Screen (NO EBRAKE Message) Ebrake code entered and worked
hook your green/white camera override wire to your parking wire that should solve your problem
Feb 20, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Refrigerators Logo
586 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
