Question about Ovens
GE Spectra XL44 Oven Overheating
Our oven "overheats" for lack of a better term. There is an excessive amount of heat coming out of the stove-top vent (near back L burner) that it sets off the fire alarm in the nearby hallway. We have tried cleaning with self-clean but it also overheats during that operation. We have cleaned with standard oven cleaner and no change.
Any info would be greatly appreciated!
  • bighermo May 25, 2008
    Model is GE Spectra JGB P35 4BB Thanks!
  • 347 Answers
Hi bighermo, Could i know what brand and model is your Oven?
Posted on May 25, 2008
  • Ovens Master
  • 19,396 Answers
It is a thermistore problem, if you replace the faulty thermic switch inside oven, it should work fine a gain
  • Ginko
    Ginko May 26, 2008
    If you use self clean it is normal that you get a temperature higher than normal. Self cleaning procedure produce an high temperature to incinerate all dirt residual in the oven.
    Normally you should not use oven cleaning solution on a self-cleaning oven.
    Run complete self cleaning procedure again (disconnect alarm while you do this) to get rid of eventual cleaning solution residuals, then check again if it overheats after this.
    A certain amount of hot air is in any case pumped off the oven normally. If this is enough to start up the alarm, then you should move the oven to a different place.
My oven will not light the oiven is a ge spectra XL44
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Apr 21, 2011 | GE Ovens
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
GE gas oven XL44 JGBP29GES1WW not enough heat
I suspect a faulty ignitor. It must draw a certain amount of amps to open the gas valve
Jun 09, 2010 | GE Ovens
Oven does not get to temp when it says its preheated
More than likely, its your oven thermometer thats taking a half hour to read correctly. The oven is probably getting there sooner. If you had a digital thermometer, the read would come quicker. So save your money,nothing wrong with your stove.
Feb 10, 2010 | GE Ovens
Gas oven is not working but broiler is working
The problem usually is the ignitor. Even if it glows it may not be pulling enough current to open the gas valve. They also are very fragile and break easily.
This tip will help you also.
Jan 27, 2010 | GE Ovens
Oven won't light.
Make sure your oven timer is not set for automatic cooking
Dec 06, 2009 | GE Ovens
Bottom burner in my oven barely comes on, in turn, not heating my oven to the temperature that is selected. Top burner (or broiler seems to work fine). The gas stove is a GE XL44 and is 6 years old. Please...
You need a new t-stat control. Your element is fine. Give us a call with your complete model number and we'll get the right part out to you asap to get you ready for the winter.
Oct 18, 2009 | Ovens
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Bake ignitor Location
ok jimmy not as bad as you think you access it through the oven cavity remove all the racks look for two screws on the bottom panel i believe they are at the front remove them then remove the bottom panel next you will see a lame spreader which is an angled plate remove it then you will see the burner bar at the back is the ignighter just match it with the new one
Feb 11, 2009 | GE Ovens
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Ovens Logo
262 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
