Question about Car Audio & Video
Hi i need a wiring diagram for a older alpine amp. it does not apair to have a model number. but apiars to be apline but not written on the amp, but this is (v12 dc straight & MOS final, PWM dc straight, 1400 watts) is written on the top lid. on R/H side GND/ ground? REM ? & B+ /battery positive? then front and rear speaker out lets x8, then L/H side (low input) CH1 & CH2 one plug each, (line out) CH3 & CH4 two plugs each. so need two no witch is for the head unit & witch is for the sub woofer. thank you.
  • 328 Answers
SOURCE: wiring car amp up
the rem wire is for switched power from your head unit usually most after market stereos(head units) have an output for the rem wire.......if not use the power antenna wire from the back of the radio (usually blue or blue white) as for the input you need to use one or the other low or phono
Hope this helps..Good Luck!
Posted on Dec 15, 2008
  • 4 Answers
SOURCE: 3 amps 2 subs sound system for car, need wiring help
it is easy to hook it up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jan 14, 2009
MrScary66613
  • 1990 Answers
SOURCE: Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Posted on Jan 31, 2009
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
  • 84 Answers
SOURCE: circuit diagram of 1400 watt woofer amplifier
www.the12volt.com/ subwoofer wiring diagrams and then find out what ohm of sub u have and how many voice coils and what ohm your amp is stable at.
Posted on Jun 14, 2009
Need wiring diagram for alpine amp. mod.#3533
What does a black wire hook up to it's coming off the board jp8
Jan 11, 2015 | Alpine Car Audio & Video
Want to install an apline stereo into a freightliner columbia
Just follow the Aftermarket Wiring Diagram and you will be fine
Apr 12, 2013 | Alpine Case Cda-7873 Cda-7875 Cda-7876...
What is the best method to connect my speakings?
Wow, thats a really powerful amp! attached is a link to the user manual for the M2000 here. You want to follow example #4, this will wire you up for 4ohms total pumping out 1500W. Plenty of bang and bump as long as your airspace is correct! :) Also, make SURE you wire up that amp with 1/0 power cable and you can step it down to 2Ga. no more than 2.5' to the amp. The worst thing to do is under wire an amp. you will also want to upgrade your vehicle ground wire from the negative (-) battery terminal to the car chassis. I would go 1/0 with that new ground, you will drive up the impedance of your overall system if your ground is too small.
Hope this helps, -Remy
Mar 30, 2010 | Alpine MRP-M2000 Car Amp
Installing apline sps- 600c
use only one set of factory wires into the crossover. then from croosover to the alpine woofer and tweeter.
Feb 10, 2010 | Alpine SPS-600C Car Component System
Hi. trying to re-install a pioneer deck where an alpine used to be. can't read the japanese on the alpine wiring to know which wire is for what. What coulour goes to the ignition, what colour is for the...
dnt get confused, follow these simple wiring .......
firstly cut off the old lug from the connected place, make sure you cut each wire seperatly....and you are going ti use the wiring agin, avoid making the wires shorter...
YELLOW..12V+ DIRECT FROM BATTERY...can be joined where alpine yellow was conected.
RED...12V+ IGNITION WIRE..can be joined where alpine red was connected
BLACK 12-, NEGATIVE....BODY GROUNDING
ALL SPEAKER WIRES HAVE +AND-, PURPLE/PURPLE----------WHITE /WHITE-------GREEN/GREEN.......GRAY/GRAY..ALL THESE ARE SPEAKER WIRES, COMPARE THE CONNECTION OF ALPINE AND FOLLOW THE COLOUR FROM APLINE LUG AND JOIN THE PIONEER LUG ....THEY HAVE BAISC COLOUR WIRE AND AHVE SAME TYPE CONNECTION..DO IT
Oct 30, 2009 | Alpine CDA-9851 CD Player
Can an equalizer cause hissing
The more ground the better,or check the RCA cables.or to see if the power wire is running any cables that power the inter.
Oct 26, 2009 | Alpine Type-R SPR-17LP Coaxial Car Speaker
Apline m350 flashing blue light
If you have a voltmeter, check that you have 12V at the power connections and also that you have 12V at the remote turn on terminal. If this is all OK, be sure that there is no short in the sub box cresated by something loose. If this is a sub that you take in and out with quick connectors (like the kind you push down and then insert the wire into the hole) be sure that there isnt a strand or two of stray wire shorting the terminals on the outside. If all that checks out, you most likely have a bad amp.
Aug 24, 2009 | Alpine MRA-F350 Car Audio Amplifier
No sound with USB and IPOD Apline IDA-X100
You connected your blue alpine wire (power antenna) to your blue wire (amplifier remote on) on the BMW harness adapter. You need to undo this, amputate your blue alpine wire (because your E36 has no power antenna) and connect the alpine blue wire with white stripe (remote power) to your blue wire on the harness adapter.
When you switch source from the radio, alpine is shutting off your amplifier through the connected power antenna wire. Since you're not listening to the radio anymore, it sees no reason why it should give it power.
Dec 27, 2008 | Alpine CDA-9851 CD Player
Wire loom for Alpine IVA C801
Ebay has a good seller for these items, specialtyelectronics.  He has all of those fairly inexpensive, I just bought one.  His stuff is genuine, some of the others on ebay have "non-factory" ones.
Nov 05, 2008 | Alpine IVA C801 Car Video Player
Alpine cda 9851r
Apline-usa.com / search for your model then look for a link that says Owner's Manuel.
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=cda-9851
Aug 11, 2008 | Alpine CDA-9851 CD Player
Car Audio & Video Logo
120 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
