Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Thin horizontal black lines
A few days ago when I turned my tv on in the morning, the picture quality had noticably reduced, and there are now thin black lines spaced about 3" apart running horizontally accross the screen. Also, the approximate 4" space on either side of the screen (occupying the difference between 16:9 and 4:3) is of exceptional poor quality. The problem is the same whether I'm watching hd cable tv or an hd dvd, so I'm assuming the problem is with the tv rather than cable box or dvd. I'm getting no errors or warnings from the tv.
  • Tony_77 May 25, 2008
    I've searched online for a service manual, but haven't had any luck finding it. I've done the '1-8-2-Power' scenario, but don't know what to do from there....
  • Samsung Master
  • 19,396 Answers
If it is tv a convergence problem, you should perform the convergence setting procedure illustrated in service manual, if this does not work the convergence board is faulty. To test if it is tv you can use a conventional aerial or a different box
If it is not tv then it can be a cable problem, or a faulty receiver box
Posted on May 25, 2008
    President:
  • 2,712 Answers
It looks like either failing convergence IC chips or a couple busted capacitors around them. This will need to be given for servicing.
You could try a hard reset first though: Unplug the TV from the power socket, remove all cabling, wait 5 minutes and replug to wall socket and redo cabling.
However, I think that you could have either convergence problems or a failing power board, for which you will need to get the set serviced.
Hope that helps!
  • Swilin Sampson
    Swilin Sampson May 25, 2008
    Ok..here's how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
    1. Begin with the TV powered off.
    2. Point your remote towards your TV.
    3. Press:
    4. Mute + 1 + 8 + 2 + Power.
    5. Your TV set should now say “Loading Factory”.
    6. Browse down to “Option” then press Enter (or the right cursor button).
    NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively
    and fairly quickly. If your TV does not enter the service menu after
    using this combination, you can subsitute MENU instead of MUTE. This
    seems to work for some sets. Also, the right cursor arrow also acts as
    the ENTER button, so try it if you’re having difficulty with the ENTER
    button.
    To exit the service menu, hit press the EXIT button or just turn off
    your TV (remember not to turn on your TV immediately afterwards!).
    However, i dont think that will resolve the issue. If you heard a kind of intermittent sound coming from the TV, it could be an indicator that the color wheel needs replacement as well. this could be another cause for the issue.
    All in all, I think it would be in your best interest to call in a service guys, as this is an internal problem, which will entail opening up the TV..
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
When I switch my tv to the HDMI input it appears to be normal for a few seconds but the screen stays black and I get a thin pink line running horizontally across the bottom right corner of the screen then...
You did not mention what you are connecting with HDMI but I have had problems with my PS3 and it is copy protection related. On a PS3, you have to connect it to HDMI1 otherwise some BlurRay movies will not play.
You might have a bad HDMI cable. I have heard the quality of cable does not matter these days but I still have had issues with the really cheap cables. I still do not buy the really expensive HDMI cables though.
Aug 29, 2011 | Zenith Z50PX2D 50 in. Plasma HDTV
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
Permanent horizontal black lines on my 50
Ive got bad news for you, about 90% of the time black horizontal lines are caused by the panel failing, your going to need a new TV. You can try replacing the timing board but the chances of it fixing it are slim..
Jan 06, 2018 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
TV - Thin horizontal line picture on screen
Is this a LCD TV? IF it is it could be something on the video processing board. Let me know the model # and well will go from there. Thank you Jay
Jan 31, 2008 | Televison & Video
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Oct 07, 2007 | Hitachi 35UX80B 35" TV
Flicker-Blinking on picture
Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
Jun 04, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
Henry  Thomas
Henry Thomas
