Question about Dryers
I have a Maytag Gas Dryer D6612. It is not warming up, there is no glow from the little door on the lower right. Is ther a pilot light that needs to be relit? The gas company was here the other day messing around. I opened the little door and cannot see anything that looks like re-lite button.
  • 4 more comments
  • Greg Bernett
    Greg Bernett Sep 30, 2010
    Why was the maintenance guys there for?
  • ginaalex Sep 30, 2010
    C17hydro - We just moved in a month ago and they were doing astandard "check." on our gas service.
  • Greg Bernett
    So did they disconnect or do anything to the dryer?
    Not that I can see. They didn't come in the house. I wasn't physically here when they came, but they reset our hot water heater so that the water in the house was lukewarm at best. That I was able to re-adjust. The dryer is very old so I thought maybe they turned gas on and off and it blew out.
  • Greg Bernett
    Let me look up a couple of things and I will get back with you...but I am here so don't think I dropped off the planet! Websites are slow....
    thanks :) I've been "googling" with no luck
  • 2,984 Answers
Okay, here is a couple of things to look for:
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Looking up a couple of other things.
Posted on Sep 30, 2010
Maytag gas dryer not heating
First make sure you have gas, then open lower section of this dryer you shoul see screws you will see a place to relight the pilot , if you smell gas before doing anything then stop your repair, see if the pilot is lit then push the red button and hold it relight pilot hold this button for a few min's after it relights, if it dosent relight check power goign to gas valve near pilot . Gas units have very little problems you may have just lost gas pressure and need to relight it , let me no ! what you see and we wuill go from there
Jul 27, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Pilot out dryer does not dry.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 22, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer is not heating now.
That unit should have a glow plug igniter. No pilot. Please be carefull lots of lent to catch fire. Good luck
Nov 09, 2009 | Heating & Cooling
How do i turn OFF the pilot light on a maytag neptune so I can fog the house for fleas?
The MDG5500AW doesn't have a pilot it has a glow bar igniter but both the washer and dryer have electronic control boards unplug both units you'll be fine.
Oct 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Sep 25, 2009 | Whirlpool Dryers
How to turn on pilot light maytag neptune dryer
Thing is the dryer does not have a"pilot" it has an electric ignition system with and electric igniter. Go here for more: Dryer Repair Help
Go to RepairClinic.com and enter your model number into the Search box at the top of our website to see all the parts available for the unit.
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer pilot light
You might have a hot surface ignitor that if broken can fall off and be somewhat difficult to locate by sight having never replaced one before.
Look at the new parts base as thats all you may have showing.
The ignitor regarless of type is very close to the gas manifold temination
going into the combustion compartment.
Replacing the new ignitor BE CAREFUL not to touch or bump the ignitors surface or it may fry out before you leave! they break easily!
I would use magnetic nutdrivers, its either 1/4 or 5/16 inch on most everything, very handy for furnace and AC work too
Aug 25, 2009 | Maytag Dryers
Hot water heater went out when they replaced our dryer doesn't
Make sure the gas valve at the dryer is turned on. Dryers use a glow plug or electronic ignitor to light the gas. There is no pilot light. Plug the dryer in and start it. Look inside the front lower panel to see if the ignitor glows. If it does and the gas does not light then the gas to the dryer is probably turned off. Look for a valve in the supply line to the dryer. Also inside near the front underneath.
Aug 05, 2009 | Dryers
I have an older Maytag D8512 with an electric igniter. When I push the start button, nothing happens. I checked the pilot light and it is off. I used a long matchstick to see if I could start the pilo
there is no pilot light. electric igniter will glow and pull amps allowing gas valve to open. if you do not see igniter glow it is bad or thermal fuse has blown. look for 120 volts at the igniter when running. if voltage found bad igniter, if no voltage trace back to fuse/stats.this assumes dryer is actually running. if drum not turning could be a number of things. door switch, fuse, etc
May 24, 2009 | Maytag Dryers
Gas dryer Maytag model # LDG410
You don't light the pilot. Gas dryers have a glow bar type ignitor. These get very fragile with age and will burn out like a light bulb. The other thing that will wipe out the glowbar is moving the machine if it gets handled roughly.
Jan 02, 2009 | Maytag MDG7600AW Gas Dryer
Dryers Logo
101 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
