Question about Nokia 5230 Cell Phone
I just installed a software "flip font" in the memory card, opened it and it didn't work and phone had switched off and it is not switched on again.
  • Nokia Master
  • 17,129 Answers
Do not install unwanted programs that can crash the software of your phone, remove the card and battery , replace only battery after 30 minutes, if the phone reboots there is no issues, but if not the software needs to be reinstalled, clear off the card and format.
Posted on Sep 30, 2010
MY samsung GT S3850 is restarting again and again once i switched the phone on
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Oct 24, 2012 | Cell Phones
Tip
NOW INSTALL FONTS ON N95 8GB 1) Install FontRouter (Fontrouter...
1) Install FontRouter (Fontrouter LT+FontrouterMan)in your memory card, or mass storage in N95 8Gb
2) using the x-plore app, make a folder in phone memory (C:/) named fonts
3) Move the fontrouter.ini and paste in c:\data\fonts
4) edit the fontrouter.ini file with x-plore like this:-
search at:
Extra font files to be loaded
ExtraFontFile=\Data\Fonts\*.*
and change it to
;Extra font files to be loaded
ExtraFontFile=C:\Data\Fonts\*.*
exit and save the file
5) Copy your *.ttf font to c:\data\fonts
6) restart the phone, and there's your new font!
if you afterwards want to change your font
edit the fontrouter.ini file again and change
Enable=1 to 0
restart and change the fonts, then Enable again to 1 and restart and enjoy the new look of the interface.
on May 09, 2010 | Cell Phones
When i insert my card it says no card inserted. i have tried numerous cards that work in other phones,also when i try to sync music it says connect failure. i have downloaded all the required software....
ok, i finally figured out the dang thing on my computer! i have a 2 gb sandisk memory card. it came in a pack with two different sized adapters that the memory card can slip into, depending on what size is compatible with your computer (i did not know that this is what you do with the memory card). i was keeping the tiny memory card in my phone (LG choc 8500), while plugging the charger cord (which doubles as the usb cable) into my computer. alas, that did nothing. more frustration--thinking it must be that i don't have the right "software" to run to access my photos and doing many searches for the "right" software solution... then the discovery with inserting the memorycard into the adapter (on my laptop, it's at the front below the touchpad-very sly sneaky place). then, after, again, nothing happening, searching forums on other lost memory card-ers, i discovered that there is a very tiny "switch" on the left of the adapter, next to the "S" on sandisc, that must be flipped down in order to "work," or grant photo/media access. a prompt came up on my screen asking me to choose which program to run/open the photos on (for me, it was windows media center), and to my relief, all my photos were there! i hope this helps. chk dis out http://repair-mobiles.com/n82-mmc-memory-card-not-detected-problem/
May 04, 2011 | Cell Phones
Font of n72
goto menu --> settings-->display--->font size --->set font size to normal or small.that will do... plz rate me !! if it helps ,if not feel free to comment
Feb 14, 2010 | Nokia N72 Cellular Phone
How to uninstall fonts in n73
Hey dude to remove fonts from your phone follow these steps
1) Connect your phone via USB to your PC and select the Mass Storage option
2) You will then see your phone as a memory card in My Computer on your PC.
3)Just go to the Resource folder and inside that there will be another folder called Fonts [E:\Resource\Fonts]
4) Just delete that folder called Fonts and then disconnect the phone from the PC and switch it off and then switch it on back. Voila !!!! you will get your old original fonts back!!! :lam: :goldcup:
hay if this not work out just take out our memory card and use a memorycard reader u will also see the resource file there then delete the font folder... thats it ^_^
Jan 14, 2010 | Nokia N73 Cellular Phone
How to increase the font size of n73
You need to download font magnifier software from any mobiles software website. Then install this application in your phone memory and then your phone font size increases.Later on, you can uninstall this application and return to your original font.You have to install this software/application because there is no other way to increase font.
Dec 24, 2009 | Nokia N73 Cellular Phone
How to formate phone memory of N72
please solve my problem dude. i instal software font remover and after using this software was not removing so i formet my phne memory but some files error in my phone relating phone memory so how i format my phone memory
Feb 08, 2009 | Nokia N72 Cellular Phone
Hw do i install a software in to my memory card in nokia n70?
first of all insert the memory card in your phone then open the memory card through the file manager.Then remove it and connect it to the pc through the card reader.Copy all the software to the Others folder. Insert the memory card once again and switsh on the phone .Go through the file manager and open the others folder of your card. There you will find the copied softwares .Just click on it and it will guide you through the installation
Nov 13, 2008 | Nokia N70 Cellular Phone
Nokia 5230 Cell Phone Logo
128 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
