Question about Motorola Mobility ROKR E6 Smartphone
My e 6 rockr is not getting charging once i put it on charging its switched on and switched off its keep on repeating
  • 17,130 Answers
Please have the adapter voltage checked for the dc output , have the battery contacts cleaned and checked for the voltage.
If either of the above is low then replace.
if Ok test the voltage at the teminal of the phone after connecting the adapter.
If Ok the battery must charge but if the charge drops off the batttery is faulty provided the functions of the phone are OK.
Posted on Sep 30, 2010
No picture no sound. Red led blinks once relay clicks once and repeats
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 25, 2014 | Sony KV-XF34M65 34" TV
Cant remove key
Try the reset for the key switch , hook up battery charger or maintainer to battery then turn key on do not crank engine leave key in on position for ten minutes , repeat a total of three times then turn key switch to off position after third cycle then remove key . Then reinstall key to ignition switch then crank the engine over and see if that fixes your issue .
Jan 23, 2014 | 2000 GMC Jimmy
Camera won't switch on, put new batteries in it, took a photo to test, since then it won't switch on.
If you were able to take one shot before the camera packed up it can be that the battery does not have charge on it and so after the first shot it has drained the battery. So check out the charge on it or repeat charging to test once again.
Other wise it can be that the camera control unit is faulty. Try and reset by removing battery for a while and trying once again.
Jul 25, 2011 | Olympus Camedia D-540 Zoom Digital Camera
Operating instructions for dsr pd177p sony video camera. I am not in postion to operate the camera, please guide how to operate the camera.
It is not very easy to say few lines to tutor ,but learn to use only by experience.Put the battery on for charging.Once fully charged slide the power switch to camera.Open the lens cap ,open the view finder display.Now you can see the picture on your screen.Set the camera to auto focus.show the camera to a white screen so as to white balance the camera.Now point at an object and do a trial Zooming using the auto zoom with your finger.The image will come closer and you can draw it to white screen.Having an object in view on the white screen,press the record button.Slowly move the zoom forward to get the right frame of the object.Press reccording button once again to stop.Repeat the process on different scenes.
Now shift the mode switch to play and rewind and play the reccorded portion.Practice.
Sep 02, 2010 | Sony Dvcam DSR-PD150 DV Digital Camcorder
My LG enV VX9900 Cellular Phone is overheated
Definitley your batery had developed reverse polarity and so it will not reain or take in charge. hence the battery will consume more power resulting in this message and it might alsoo be dangerous to keep this on. I would advise you to put in new battery and do the intial charging as required. Keep it on for 8-12 hours of chrage then discharge offf in use fully and rechage again. Repeat this for three time before your battery becomes fully functional. hope this helps. Good day
Jul 22, 2010 | LG Cell Phones
HOW TO DOWNLOAD THEMES TO MOTOROLA ROCKR E8?
if you can Downnload motorola phone tools or the p2k phone tools from Motorola youll be able to flash your phone with new skins..www.modmymoto.com can help with all this..new skins and the phone tools programs
May 15, 2010 | Motorola Mobility ROKR E8 Cellular Phone
Motorola rockr e6
motorola l6 phone is locked unlock switch the side key lock
Mar 17, 2009 | Motorola Mobility MOTOROKR E6
Motorola rockr E6
Seems like a reminder setting, I would check your missed call, or message reminder settings to see what they are set to.
If all else fails a master reset should clear this.
Jul 21, 2008 | Motorola Mobility ROKR E6 Smartphone
My battery on my iphone runs out in 2 to 3 hours. What to do?
I think you must check your charger and if ok replace your battery
Mar 31, 2008 | Cell Phones
Motorola Mobility ROKR E6 Smartphone Logo
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
