Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
Saeco incanto sirius
Hello, I cannot get my incanto sirius to ventilate and in turn no hot water or steam. Also my digital display all works for the exception of the menu button which controls the machine....could this be the reason my machine wont ventilate? thank you
  • randjgarner Jan 01, 2009
    while making a coffee using the steam pipe the machine stopped making steam and the instruction came up to ventilate,I then tried to decalcify it did this without any trouble but on the rinse it stopped working with a notice to ventilate again which I cann't do as the ventilate function is not working as is the hot water and steam there has been plenty of water in all the time
  • 515 Answers
It can be the touch board or the "water turbine" in the machine
Posted on Jul 11, 2008
Hot water ventilate problem for Saeco INCANTO DELUXE Espresso Machine 2 signs at a time "hot water" +"ventilate" "
Place a jug under the milk frother and turn the steam knob to allow hot water to flow.
Ventilate will clear after a short time
Jan 27, 2013 | Saeco INCANTO DELUXE Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
What does ventilate mean on my Saeco coffee machine. It will not work now.
i had this problem too once. its also could be because you have put hot water in the water tank....i had a family member do that and thats what it said....run cold water through wand and see what happens...
Nov 07, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
My saeco s-class incanto sirius machine keeps say replace water filter & ventilate even after I replaced filter
Sounds to me that water is not getting to the pump. Try charging the water filter before using by letting it sit in some water for about 5 mins.
Jul 23, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Does not come off ventilate mode. Re: S-Class incanto sirius mode
Try this push in steam knob when it calls for ventilate, especially if you are steaming or drawing hot water, if that works the the steam valve or the tap rod needs to be replaced.
Dec 28, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Incanto Classic Espresso Machine Saeco Coffee Machine Type SUP 021YDR Display shows Ventilate when I follow instructions and turn the Hot Water and the water knob the water is not coming through....
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Apr 12, 2008 | Saeco Incanto Classic Espresso Machine
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
572 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
