Connections Hi, How do I connect my non-digital RCA TV, my non-digital RCA DVD/VCR recorder and my new digital converter so that I can record from local TV channels?
    Genius:
  • Televison & ... Master
  • 1,673 Answers
You need compatible equipment!!! Or, go to your local TV/Audio store and buy converters.
Jerry G.
Posted on May 25, 2008
I replaced my TV and now my VCR Zenith Model 2100 will not record
Digital TV can use component video and stereo connections to record on analog VCR. Analog VCR needs DTV converter to record digital TV channels. VCR play back use AV channel on TV.
Feb 11, 2012 | Zenith Televison & Video
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
I have a new digital tv but can't get my vcr/dvd player recorder to work. Can I use the converter box on a digital tv? will it work to record and play.
The output connection from the VCR/DVD needs to be different for the new digital TV. Instead of using the RF output from the VCR, use the video and audio outputs and connect them to the video and audio inputs on the digital TV. When you want to watch the VCR, select "video in" on the TV. The digital converter box should be hooked to the input of the VCR so you can record programs off-air.
Jun 14, 2009 | Insignia Digital-to-Analog Converter for...
Vcr/dvd combo recording problems
I would need your exact model # to get very specific, but in general:
The "External tuner" will need to come from your TV or a cable/sat box, generally. If your TV has a Video OUT or a Monitor OUT (most television don't), you can hook a yellow AV/RCA video cable from the TV to the Magnavox. You will also need to hook a red/white audio cable from the Audio OUT of your TV to the Magnavox.
Your TV probably doesn't have a Video OUT, so you will need to buy a box. A digital cable box for your cable service would be the best investment. Alternatively, if you can find a digital-to-analog converter box (but these are iffy). Once you have one of these box types, you will need to hook a red, white, and yellow AV/RCA cable from the video/audio OUT of the box to an available video/audio in on your television.
Once your connections are correct, the general rule with tuner-less recorders is: If you can see the channel that you want to record on the television screen, then you will be able to record it.
One final note about Feb 17, 2009: Thanks to Congress, the digital transition date was moved to June 12, 2009 - many areas have already switched, but there is at least a chance that you are in an area that hasn't switched yet.
Let me know the exact model # of your television, and I can tell you if it has a video/monitor out - or, let me know what type of box you decide to buy.
-Tha Mp3 Doctor
Mar 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Can't recorder digital broadcast
Hi,if your vcr is an analog machine then you will not get a signal.If you have a seperate digital box then you can connect this via a scart lead to av2 on the vcr.Best thing though is to buy a digital dvd recorder.hope this is of some help.jamie
Mar 02, 2009 | Zenith XBV443 DVD Player/VCR
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
I have a ViP 722. It has no rf output for TV1, just the hookup for TV2. The multi RCA hookup for HD. HD is not as important to me as is a clean picture and audio on my TV. No matter how I do it, I get a...
Okay I am not positive I have this right as far as the configuration of the system but I will give it a shot. If you run the 722 to the tv using rca's you get the hum. I assume this as there are no inputs on a dish 722 receiver. I can suggest one possible solution which is to buy an rf modulator. It will convert the signal from rca to coax so you can connect as you wish. There are several types out there so ensure you get the one that converts from rca to coax. I would suggest the following configuration: Remove all connections from tv and hook 722 up via rca's to rca input 1 on the tv, check for hum. If it is present now you need a new 722 as it is passing to much power thru the connection. If there is no hum connect your cable and tivo to the tv via whatever inputs you have remaining. Lastly connect the DVD player to another input that is free. You will have to system through your inputs to view the three sources but should not have the hum. I hope this solves your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Connect
Does your set have compatible connectors on the rear of it? Did you read the instruction manuals that came with the new equipment? Did you ask your dealer???
Jerry G.
May 25, 2008 | RCA 32F531T 32" TV
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
