Question about Compaq Armada 7770DMT Notebook
My compaq armada 7770 just doesn't come on anymore. i have so much old work disks that i need and in the past i would purchase another 7770 and just take the drive out of one and put it in the next one. currently i haven't found anybody selling any and i have so much work. how can my dos based disks work on a windows based computer? p.s. i'm a court reporter so reloading the old program is almost impossible because of disks that are no longer in existence.
  • Compaq Master
  • 2,170 Answers
Why not take out the drive
and put it in a cheap USB driver enclosure
now any PC can read all those files.
why not.?
why make this so hard,its just files.
nothing more complex that say Fat32 files or NTFS.
you dont have IT departments to do this for you?
here , i had to read the
compaq armada 7770 spec. to see it guts.
its got a relic PATA drive, aka then as IDE.
this size is (length /width/depth) 2.5" i think the specs are rare !!!
so buy this.
http://www.ebay.com/itm/Vantec-Nexstar-3-IDE-PATA-2-5-External-Hard-Drive-Enclosure-USB-2-0-/112432727250?hash=item1a2d8344d2:g:pdgAAOSwYvFZNevp
plug in the drive the usb connect it and bam ,all data there
go to my documents folder and sure there.
i cant guess how or where you put documents, only you know that
but anyone can search the whole hdd, for say *.DOC
or pdf. or?
Posted on Jun 27, 2017
daverh
  • 117 Answers
SOURCE: Compaq Armada e500 won?t recognize the cd drive
Simple things first: Assuming the CD drive is removable, remove it from the laptop then re-iinsert it making sure it's pushed home properly so that the connectors seat properly.
If, again, the drive is in a bay (i.e. it's removable) then it may be the connectors are worn/damaged. If it's the drive connector then it may be repairable or you might pick up another drive, perhaps on eBay. It may also be that the drive has simply given up the ghost - so back to eBay :) If the connectors on the laptop have got damaged then you're looking at dismantling the laptop to repair/replace them, if that's possible.
If it's an external drive then the advice is very similar - check out the connectors first. If they look OK then you probably have to suspect the drive itself.
For either type of drive, there is always the small chance that the IDE controller channel on the motherboard has died - I have seen this happen in rare cases. Your options then are a bit limited. IIRC, that PC has no USB2 and even if it did, it wouldn't boot from a USB CD. You can get a PCMCIA interface card (now called simply PC interface) for an external CD. Depending on the card-drive interface, you might be able to boot from that.
If you need to install software onto the machine & have another (desktop) PC to hand: remove the disc from the E500, get a 2 1/2 to 3 1/2" disc adapter & temporarily attach the drive to the desktop as a secondary (i.e. not boot) disc. You can then load software onto the drive although you can't do a Windows install that way. If the machine already has an old version of windows on it, you can copy for example, the XP install files onto the drive, put it back in the machine & run an upgrade. Not the most desirable result but may be OK.
Posted on Nov 03, 2007
tat4u
  • 520 Answers
SOURCE: BIOS upgrade?
u can use usb cddrive without update bios but unlike later versions of windows where you just plug it in and it detects it you will have to use an instalation disk for system to recognise device same with usb stick.
what mem do u have and consider xp (need at least 40meg to install)if u can fit 256 or higher ur laughing mem cheap as buttons these days.
Posted on Apr 12, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Installing a Seagate Dive into an Armada M700
Here at my shop I have run into this exact same problem on several P3 Compaq's and a few Toshiba's. I found that some of these machines, not all, but some, will not accept the 5400RPM drive, but will take the 4200RPM drive just fine. It's just weird because some that do are the exact same model, and I'm not real sure why it won't accept them. I've looked into it and the best that I can surmise is that 5400 is too fast for the reading system in the bios, or it's a power issue. Go with a 4200RPM drive and you shouldn't have any problem. You won't be able to tell any difference in the machine's performance between the two RPM speeds.
Posted on Aug 01, 2008
SOURCE: compaq armada 1500
You can run XP on the Armada 1500c but with a lot less satisfaction than 98SE. There is really no advantage.
Posted on Oct 21, 2008
bootz84
  • 197 Answers
SOURCE: I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
Posted on May 04, 2009
I have a laptop compaq armada e500,but i forgot my admin possward.how can i reset it to gain access to my laptop?
Hello.
You can create from another computer and run a Password Reset disk.
Download and burn to CD. Copy/paste this link:
http://pogostick.net/~pnh/ntpasswd/cd080802.zip
Download this file and burn it to a CD.
Put into drive and turn on PC. Boot from your CD.
Follow instructions, choose the correct USER and BLANK out the password.
Make sure you say OK to write the data, and reboot.
The Administrator logon password will now be blank.
Note: Substitute a flash drive for CD, if your system doesn't have a CD drive.
Hope this helps.
Oct 04, 2011 | Compaq Armada E500 Notebook
I have a Caompaq Armada 7770 DMT that is set to fast boot
om my armada m300 before the boot screen comes up i tap f10 a few times to get in service mode, it mayy not b f10 on urs though, may b f3 or similar.
Apr 11, 2009 | Compaq Armada 7770DMT Notebook
Cannot get past the log in screen asking for user/password
There are Linux password recovery programs on the Internet that allow you to remove the passwords on User accounts.
You can Google search and download the program, you then need to make a boot CD with this program.
ALternately you can purchase a copy of Windows XP or Vista and wipe Windows 2K and install XP or Vista on the laptop.
Jan 15, 2009 | Compaq Armada 1592DMT Notebook
How do I get past this Drivelock HDDBay password
mabey reformat hard drive using the windows xp disk then reinstall operating system
Oct 28, 2007 | Compaq Armada E500 Notebook
My compaq Armada E500 wont come on
Replace hdd couse the pc dont recognize hdd..First go to the bios and load optimal default or optimized default and pres F10 and restart
If it wont work just buy NEW HDD
Oct 19, 2007 | Compaq Armada E500 Notebook
80 GB disk drive
Hi, I can help you with problem. Is the new 80GB drive partitioned and formated?
Sep 16, 2007 | Compaq Armada E500 Notebook
Issues with my compaq armada
This means that your hard drive has failed or has become disconnected and it cannot find the boot.ini to enable Windows to start. When you say youv'e tried all discs which disks do you mean?
Jan 09, 2007 | Compaq Armada 1500C Notebook
Need software
Your only hope is that you have a Windows XP pro installation disk to either repair or re install Windows, although a repair is only of use if you still have the principal windows installation. How is XP still there if the notebook has been formatted? If your recovery disk ;which I recon was on another partition on the hard drive is long gone, then the only solution is to purchase XP, although XP home is a cheaper, but just as good a version please rate this solution.
Nov 13, 2006 | Compaq Armada E500 Notebook
Compaq Armada 7770DMT Notebook Logo
128 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
