Can I add external speakers to my samsung plasma HPT4264" without using an amplifier and without having to use a separate remote?
  • 736 Answers
One way around an amplfier and a separate remote would be to connect Ipod docking speakers to the headphone jack on this television.
I am looking at the back of the television and I believe I also see two red and white composite/RCA audio outputs. You may be able to attached powered speakers (they should have their own power supply and volume control) to one of the two audio outputs on the back of the television but this does not always work.
Posted on Sep 30, 2010
Hi,i hear alot about bi wireing could someone explain what it actually is used for and what's it meant to do could I'm thinking bout trying it on my speakers?
It's a big job, but the results are great. Bi amp-ing is where the tweeters and mid range speakers are separated and connected to separate amplifiers. You'll need to have the correct gear before messing inside your speakers. You'll need to have another amplifier. Not knowing what amp you have now, getting a stereo signal into the second amp may be a problem since you'll need a line level signal into the second amp. An external crossover is best. Technically, you could use the ones in the speakers, since you'll be removing them anyway. Now for the speaker mods: On the panel where the posts for the speaker wires are you'll need to install another set of binding posts. We're assuming you have separate subs. Open the speakers and remove the cross over. The wires from the original posts should now connect to the mid range speaker. Add wires from the second set of posts and wire it to the tweeters. Now connect the output of the amp to the removed cross over and wire the mid range out on the cross over to the posts that connect to the mid range speaker. Do the same for the tweeters.If you have three way speakers, you'll have to run a 3rd set of wires from the crossover to the woofers in the cabinet using another set of binding posts. Controlling the volume on the second amp will be difficult since you'll have to adjust it manually. Remote control volume level will be lost on the second amp.
Aug 08, 2015 | Audio Players & Recorders
How can i add external speakers to my lg 50pk950 tv and still control with my tv remote without also adding an amplfier?
Use a wireless speakers system and connect it to the Audio Output RCA jacks on the back of your set( red/white). You can find various style to fit your decor. Google it.
Nov 30, 2010 | LG Infinia Series Plasma HDTV 50PK950
Can i connect speakers to my 47ich plasma tv without a surround sound system
I would need the specific model to tell you for sure. But most plasma's do not have that ability as they would need an external speaker amplifier built in which they do not do. So most likely the answer is no.
Thank you,
Lee
Aug 10, 2010 | Philips Televison & Video
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
Sound gradually went right off over time, on a colour TV samsung sp43t6hp even when the remote was used to crank up the sound level to max.nothing was heard. Are the external speakers on a separate...
no the amp supply's sound to internal or external, you may be able to connect the audio out RCA jacks to your stereo aux input jacks if you have one and run it that way
Jan 27, 2010 | Samsung Televison & Video
I have a set of external speakers that are about 10 years old but still provide surround sound. When i plug them in to the tv i see no option in the menu to select external spearks. It just displays TV and...
do the external speakers have a amplifier or is it just speakers on their own?
forget the settings and connect your speakers using a phono cable to the:
prog out to audi amplifier teminal
should be in the bottom left of the connections pannal at the back
but this connection needs a amplifier
go here
http://service.us.panasonic.com/OPERMANPDF/TH42PX75U.PDF
for further details
most important page is 40 and 41
Jan 01, 2010 | Panasonic TH-50PX75U Plasma HDTV
Plug in external speakers w/ volume very low in HP2009m screen
check if the external speakers u plugged in came with an internal amplifier, if not then u will have to use an external amplifier to get max output from your external speakers.
Sep 02, 2009 | Audio Players & Recorders
How do i hook external speakers to sony bravia television
The proper way to do this would be to use the audio output from the TV, either analogue left and right or the optical port, and send it into an dedicated amplifier or AV receiver. You can then use the amplifier or receiver to power the external speakers. If you are using a dedicated amplifier with no volume control you will want to change the audio output setting on the TV to "variable out" as oppose to its current "fixed out"settings. You can find this in the TV menu, usually under the audio settings. This will allow you to use the current TV remote to adjust the audio volume coming out of the external speakers.
Aug 21, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Problem connecting cable wires for Sony PFM-42B2 42 in. Plasma TV
I have this screen and my version does not include audio - I need to connect to an external amplifier, in my case my home theater.
Nov 18, 2008 | Sony PFM-42B2 42 in. Plasma HDTV
Magic Sing EG-18000 Microphone Delay
i bought et18k. just the same as yours.its 2 days old and has the same problem. the technical assistant says that its because of the digital setting that new tvs have. there are two ways to solve this though:
1. connect the video (yellow plug) to the tv. and the other two plugs (yellow and white) to the stereo. when i say stereo, its not the dvd home theater system that you have but a separate one. if you connect it to the home theater that you have, it'll just sound the same, you still have the delay.
2. connect the magic sing to the older tvs hangin out. and you'll get no problem at all.
**TVs such as sony, samsung, philips, sharp and all plasma tvs including other newly designed tvs will have the delay since they all share the HDMI thingy that causes sh*t.
Mar 16, 2008 | Magic Sing Along Consumer Microphone
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
Electro Med Services...
