Question about Amana ALW480DA Top Load Washer
Washer leaking I need help with my washer leaking. The hoses are connected, but there is a lot of water on the floor once the cycle is finished. Is this something I can fix myself?
    Novelist:
  • 177 Answers
You need to remove the front panel and look where the water is coming from. fill the washer on the small water level. then turn it to spin and watch for water.
If its the pump you can replace this, if its a tub seal, up under the tub thats a major job, get someone to give you a quote over the phone. You may want to replace the washing machine. based on age and $$$
Posted on May 26, 2008
My whirlpool washer is leaking from the front center. Happens during spin cycle I think.
Hello.
If your washing machine is leaking, don't rush out to buy a new one just yet. Sometimes simple repairs to the machine can fix the leaks saving you hundreds of dollars and days of shopping for and installing a new one. Luckily, you don't have to be a master electrician to do repairs. These steps will walk you through the basics of fixing a washing machine.
Bellow are Instructions on how to solve the problem of leaking washing machine
    • 1 Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
    • 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
    • 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
    • 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
    • 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
    • 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Thanks.
Sep 03, 2011 | Whirlpool Washing Machines
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaks from under the front of the machine.
If you are having a problem with your washing machine i.e leaking, don't rush out to buy a new one just yet. Sometimes simple repairs to the machine can fix the leaks saving you hundreds of dollars and days of shopping for and installing a new one. Luckily, you don't have to be a master electrician to do repairs. These steps will walk you through the basics of fixing a washing machine.
Instructions
  1. Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
  2. Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
  3. Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
  4. Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
  5. Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
  6. Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Good luck and thank you and thanks for using fixya.
Jan 30, 2011 | KitchenAid KAWS750L Top Load Washer
My washer stopped during the spin cycle. Now I can get it to fill with water But aggitate and spin it just makes a noise and the tumbler is locked up tight
Your shaft coupler / motor coupler has likely broke. Not too hard to fix yourself, but you will have to remove the water from the washer first.
Remove the clothes, place them in the bathtub. Roll a garden hose from the washer to outside where drain water won't matter. Tape the garden hose to the drain hose, and lower the drain hose to the floor. Water will flow through the garden hose outside. Turn the washer over, follow directions supplied with new part, and replace the motor coupling. When finished, reorient the washer, remove the garden hose, place drain hose in the drain stand pipe. Run the washer through a couple of full cycles, then rewash the clothing.
Jun 11, 2010 | GE WBSR3140DW Top Load Washer
Leaking
Hi
Please Follow this Instructions:-
Step 1 Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
Step 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
Step 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
Step 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
Step 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
Step 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Thanks for contacting fixya.com
Oct 30, 2009 | Washing Machines
Water leaking
hi friend,
  • Step 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
  • Step 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
  • Step 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
  • Step 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
  • Step 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part
  • hope this helps u
    thank u for using fixya
    please rate me.................
    regards
    sivaranjini
    Sep 12, 2009 | Kenmore Washing Machines
    Whirlpool duet washer model # GHW9100W pours water on the floor
    1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
    A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
    The other two options are when the washer is agitating or pumping the water out between cycles.
    2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
    If it doesn't, then run the drain cycle to see if it gets worse or better.
    Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
    3. Wait until the water has been pumped out, lift the lid and check the drip again.
    When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
    If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
    WARNING. You are working with a moving, electrically hot machine that could flood.
    You must take your time and not put your hand or hair in somewhere that can catch you.
    You should not have to get into the upper control center, thus reducing the shock hazard.
    4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
    Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
    There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
    5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
    Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
    Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
    Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
    Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
    WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
    Stay clear, and watch your hair and hands.
    Once the machine is full and starts its cycle, look for leaks.
    Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
    Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
    Remember, water runs down; where it drips is not necessarily the place of origin.
    6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
    If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
    If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
    If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
    Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
    Replace any valves that are cracked.
    Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
    They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
    The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
    Replace the nozzle if you find cracks in it.
    If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
    You can make a closer inspection by tipping the unit over onto it's front or side.
    Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
    The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
    Replace a worn gasket. A hole in the bottom of the tub can develop.
    If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
    If the hole is larger, replace the washing machine or tub.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Small amount of water from washer
    ck around pump at place motor shaft connects ..that is mot likely place
    Sep 12, 2008 | Kenmore 24032\24036 Top Load Washer
    GE top load washer leaks on floor
    Check your hoses mostly the small hose going from the side of the tub to the water switch these come off a lot. you need to look and see if the seal is leaking from the center of the tub you do this by putting water in the tub and just looking around the bottom of the tub and transmission
    Dec 29, 2007 | Washing Machines
    Amana ALW480DA Top Load Washer Logo
    150 people viewed this question
    Top Amana Washing Machines Experts
    Dan Webster
    Dan Webster
    Charles T Nevin
    Charles T Nevin
    Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
