Question about Canon PowerShot A75 Digital Camera
Snap picture button jammed
Hello
I dropped the camera. Now the snap picture bottom jammed. Also, cannot rotate lever for zoom etc just above it either. The whole aparatus jammed back into body of camera. Tried to get at the assembly to move it foward, No luck.
Help
Anthony
  • Anonymous May 25, 2008
    Hello
    Problem Solver:
  • 5 Answers
If you have some jewelers phillips screwdrivers (very small tips) you can take off some screws and maybe pop a cover back in place. The zoom lever has 3 screws holding it in....2 at the bottom of the battery compartment and one in the compact flash card area. Go here for pictures....
http://menthol.hit.bg/E18.html
Posted on May 29, 2008
Why does my Panasonic DMCFZ28 take pictures when I push the zoom lever?
I suspect the snap key is shot circuited, use contact cleaner spray in the click button often press it to get ride of possible carbon shot circuit between the switch. in some cases the processor will malfunction, and if moisture or water particles gone inside, you must open the cam and clean the motherboard thoroughly with PCB cleaning agent.
Apr 10, 2016 | Panasonic Lumix DMC-FZ28 Digital Camera
We have this camera and it will turn on & zoom. The camera will not snap the picture. What could the problem be? We have changed the batteries without sucess The camera has hardly been used. Larry
The problem could be that you're not fully pressing the shutter button. Many people squeeze the button until something happens... that's the half press that causes the autofocus to operate etc. Because something happened, they don't continue to press hard enough to actually take the snap.
Of course it's also possible that the plunger on the shutter button is too short and isn't reaching the switch properly, but I've only seen that on a kids cheap camera where it was squeezed too hard with impatience because cheap cameras operate slowly.
Oh, and one more thing: are you squeezing the button for long enough? I don't know how slow this particular model is.
Jan 20, 2011 | Sanyo VPC-S670 Digital Camera
Film Rewind Button Problem!
mistermanage,
turn the advance lever to charge the shutter.or open the film door and rotate the drive sprocket to the right, this will release the button. if the button didn't pop up then the bottom cover will have to be removed in order to release it manually.
Feb 03, 2009 | Vivitar V3800N Zoom 35mm SLR Camera
Powershot A620 Zoom Lever
Remove your batteries and look inside the battery compartment. Notice that there should be three small phillips screws at the bottom of the compartment. Tighten up all of these screws.
May 12, 2008 | Canon PowerShot A620 Digital Camera
Sony DSC-P100 won't snap picture.
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Dec 18, 2007 | Sony Cyber-Shot DSC-P100 Digital Camera
Powershot G6 -- Zoom button stuck
Does it display any of these messages
Dec 15, 2007 | Canon PowerShot G6 Digital Camera
Malfunctioning of Nikon 2100
I had the same problem.The shutter button is faulty and is always half pressed - auto focus is operational (this is the step before actually the picture is taken. Try to clean it up with some special electrical contact spray. if this does not work - need to replace it - Not a simple job for the novice. You might need to take the camera to a service center for a spare on-off-expose button. I had an old faulty camera where I took the button from it. That solved the problem.
Nov 27, 2007 | Nikon Coolpix 2100 Digital Camera
Sony DSC-P72 won't snap a picture
Have you done a "hard" reset?
Under the jack cover (below the zoom rocker on the back of the camera) there is a small "reset" button. You'll need to press it with a sharp object, and hold it down for a few seconds. If it was a setting problem, this should resolve it.
Nov 11, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
The camera zoom got jammed
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 at my shop. Broken drive gears are generally This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Jun 14, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot A75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
