Question about Ovens
Whirlpool accubake gr440lxmc oven manual - Ovens
aborcass
  • 2651 Answers
SOURCE: Whirlpool Gold Accubake oven
depress the broil button for 5 seconds it will revert back to Farenheit
Posted on Feb 24, 2008
SOURCE: whirlpool accubake oven error code
I am receiving an error eo f5 and it won't bake
Posted on Jul 17, 2008
SOURCE: whirlpool gold accubake
I have the same problem, Whirlpool is not a good, quality appliance that you could get.
For the error code, refer to link below - not all are accounted for.
http://www.repairclinic.com/0078.asp#Whirlpool1
For a end users horrible experience with this appliance manufacturer...it's worth reading.
http://www.consumeraffairs.com/homeowners/whirlpool_ranges.html
Posted on Sep 30, 2008
SOURCE: whirlpool accubake oven problem
I had the same problem and followed the process listed above....yes, I did unplug/turn off the circuit and am alive to share this update! Right off I noticed that the ribbon cable was loose. For those who have tinkered around with other electronics such as a PC, etc., note that this ribbon cable is not secured by the connector (atleast in my case). Reseated the cable and turned the power on. Voila- the bake option works. Tested it by turning it on for 20-30 seconds. Touched the bake element and got proof that it was working fine (via a singe of the ring finger ;-)).
About three minutes or so later, the display started to beep with an error code - E0 F2. A shorted keypad is what it stands for. The clock was still operable. I could still select the bake option, broil option, etc. Ran a test bake cycle but it turned off after a minute or so and started to display the E0 F2 code again.
Started the process all over ie turn power off, take panel off, reseat ribbon cable. Turn power on and test by holding the Cancel button for five seconds. Still displays the E0 F2 error. Waited for 10 minutes but this time no more beeping or error display. Ran a preheat cycle for 4+ minutes without any problems. The oven warms up and the bake element glows red. Hopefully, all is well. Will see what it does when we bake something the next time.
Thanks to PropHeadTwo and others for their contributions.
Posted on Dec 18, 2008
  • 22 Answers
SOURCE: whirlpool accubake oven door will
F5 fault codes are latch mechanism problems. One means the latch won't lock, the other means the latch won't unlock. Odd you're getting both...
Posted on Apr 25, 2009
I have a whirlpool accubake wall unit oven Took out door to clean glass now I cannot put door back together
you have a couple of hinges you have to pull out at about 45 degrees then slide door down on them and shut door
May 05, 2016 | Whirlpool RBD245PRB 24-inch Double Wall...
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Need manual for whirlpool gr440lxmc
quicker to find than logging in here and asking the question
Manuals and Literature
Sep 18, 2014 | Ovens
Replace outer glass on oven gr440lxmc
You have to take the inner glass off first to get to the fixings for the outer glass. its normally 4-6 screws holding the frame for inner glass in place good idea to keep the parts in order for refix.
Sep 18, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool accubake oven manual
If you can supply Whirlpool with the model number, they may be able to provide a manual
Aug 19, 2013 | Ovens
Setting clock on whirlpool accubake oven
You will need your model number from inside the lower drawer or oven door and then click here=> Whirlpool Guides and User Manuals If you need Adobe Reader Click Here=> http://get.adobe.com/reader/ If you are having service problems with your dryer I will answer your questions. Let me know and please rate if helpful, Thanks Sea Breeze
Nov 07, 2011 | Whirlpool Ovens
Whirlpool Accubake instructions
I have lost my instruction manual and I need to know how to use the self-cleaning feature on my range
Oct 03, 2009 | Ovens
Whirlpool accubake rbd245pdb no power to control
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
If all check out ok with all the above, replace the ERC
Jun 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
128 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
