Question about Brother HL-2170W Laser Printer
We had a power out for a few seconds and the bl 2170w only comes on for less that a second. If I hold the Go button when it is turned on the 3 indicator lights stay on. If I let go and repress the Go button only it will light on each press. No action happens at any time. this has happen before and resolved itself but I'm not sure what was done to make that happen. The Go light will not stay on at all now. Only in the above instances. How can you help?
Unplug the power to the printer before the power comes back on to avoid any damage due to surges when the power is back. After the router is back on and working. Plug your printer back. Then press the blue button for 10 seconds so that the setup page is printed. Your printer is now back on.
Posted on Sep 30, 2010
Totally dead.No display, no led blinking.
Check power coming out of transformer, may need a new one.
Nov 16, 2015 | Yamaha RX-V375
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
Won't turn on, won't eject disc
best thing to do to eject disk is
1.power of the console
2. hold the eject button and the power button down at the same time
3. then reach around to the back of the console and put the switich on
4. hold for ten seconds and thhe disk should come out
hope i could help!
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
I'VE HAD MY DRYER 3 YEARS. POWER COMES ON BUT WHEN YOU PUSH START BUTTON THERE'S JUST A PAUSE AND THE ERROR CODE " F". PLEASE HELP!!
Select any one button (except POWER, START, and STOP) and follow
the steps below, using the same button (remember the button):
Press/hold
3 seconds
➔ Release for
3 seconds
➔ Press/hold
3 seconds
➔Release for
3 seconds
➔ Press/hold
3 seconds
All indicators on the console will
momentarily turn off, then turn back on with 88 displayed. After
5 seconds, the Automatic test begins.
Use the tech sheet info on page 2 as a starting point
Note to get the exact tech sheet or manual for your machine go to ServiceMatters and post your model number.
May 03, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
2170W wireless connection to mac computers
My suggestion would be to connect an ethernet cable from the printer to the router. This is a more stable connection for the printer on the network.
All of your wireless computers will be able to connect to it and print to it as long as they are connected to the network.
To get the printer back in wired mode, you will need to reset the printer and network card of the printer.
1. Turn off power
2. Hold down go Button while switching back on
3. Wait 2 secondes before letting go and press the go button 8 times quickly
4. Wait for the unit to finish warming up
5. Repeat steps 1 and 2
6. Wait 2 secondes before letting go and press the go button 7 times quickly this time
7. Wait for the unit to finish warming up then plug in the ethernet cable.
Mar 28, 2010 | Brother HL-2170W Laser Printer
My playstation 3 will not load up the green light comes on but nothing happen a few minutes later it says 'cannot start correct hard disk was not found' can anyone help on how to fix or how to recover my...
Try this, but keep in mind that one of the options wipes all your data.
These should be safe to use, and 'should' keep your data.
  • Restore Default Settings
  • Restore File System
  • Rebuild Database
  • Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
    Step 2:
    1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
    2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
    3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
    Step 3:
    1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
    2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
    3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
    4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
    5. Then you will see the Safe Mode menu.
    Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
    1. Restore Default Settings
    2. Restore File System
    3. Rebuild Database
    4. Restore PS3 System
    Oct 04, 2009 | Sony Video Game Consoles & Games
    Can't get my BL-PA300KTA to connect. I have plugged it in and pressed the Setup buttons (within 3 seconds Mater and Terminal). The PC, LAN, and Master lights are ligting up as they should (I believe), with...
    I use these and the previous model without any issues.
    1. They must be plugged into the wall socket. It's okay to use an extension cord between the adapter and the wall, but never a surge suppressor or UPS
    2. The master need to be connected to you router
    3. To test your connection do the following
    -Plug the master into the wall at the router location
    -Plug the slave into the outlet where the computer will be
    -Press and hold the setup button on the slave unit only for 3-5 seconds
    The leds on the slave will flash for a second or two and then turn solid.
    The number of solid lights you see tell you what your connection speed will be 0-no connection, 1-<10MB , 2=-10-30MB, 3->30MB.
    I always unplug the ethernet cables from the adapter when testing, but I don't know if that is necessary.
    I have never gotten less then 2 leds in my house, but it's new.
    Sep 01, 2009 | Panasonic Network Camera HD-PLC Bridge...
    Cant Login to Dir-450 Router
    Try this:
    1. when the unit is powered on, hold down its reset button for 30 seconds
    2. while still holding down the reset button, unplug the router from power and hold for an additional 30 seconds
    3. still holding down the reset button, turn on power to the router again and hold for 30 more seconds After this process (a total of 90 seconds) is complete, your router should be restored to its factory default state.
    Aug 24, 2009 | Computers & Internet
    Playstation 3 does turn on but no picture or sound at all
    hold the power button down for 20 seconds
    you will hear a few beeps but keep holding the power button in until you see a picture
    Jul 04, 2009 | Sony Playstation 3 (PS3) Console
    Brother HL-2170W Laser Printer Logo
    65 people viewed this question
    CheckitRight
    CheckitRight
    James Cagle
    James Cagle
    Samyfam
    Samyfam
