Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
THE FAX MACHINE MODEL 1840c RINGS BUT NEVER SEEMS TO RECEIVE THE FAX- THE CONNECTION BREAKS AND NOTHING PRINTS- WHAT IS WRONG?
    Problem Solver:
  • 17 Answers
Is unit set to auto answer, yes , is telephone cord good, yes , call the fax number and listen for the tone, if no tone then modem board is defective
Posted on Sep 30, 2010
Fax &printing
bro your fax is getting old i think so.if not want buy a new one then open it and just clean it inside with a brush.thats it
Apr 24, 2010 | Brother IntelliFAX 1840C Plain Paper...
HOW TO RECEIVE A FAX
make sure the phone cord is in the right slot and make sure u are getting a dial tone if not could be phone line issues call the number yourself and make sure your getting a clear ring
Aug 28, 2009 | Brother IntelliFAX 1840C Plain Paper...
No dail tone
IS THE PHONE LINE PLUGGED IN TO THE RIGHJT JACK YOU WILL NEED TO CHECK THIS OUT FIRST GOOD LUCK BROTHER TECH
Jan 29, 2009 | Brother IntelliFAX 1840C Plain Paper...
Don't know how to set up brother intellifax 1840c
Plug the fax phone cord into the LINE port of the machine. The rest is automatic.
Jan 16, 2009 | Brother IntelliFAX 1840C Plain Paper...
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
1840C Brother fax machine
Do you have ink / toner / paper?
Unplug the power cord for 10 seconds.
Sep 08, 2008 | Brother IntelliFAX 1840C Plain Paper...
Not recognizing new phone line - Double Ring
Fax machines are designed to have their own dedicated fax line.
Anything else is a **** shoot.
Aug 12, 2008 | Brother IntelliFAX 1840C Plain Paper...
HP640 not receiving with Distinctive Ring Option
You need a dedicated ANALOG phone line.
A DSL filter screens out ANALOG signals to a DSL device.not the other way around. There are no DIGITAL fax machines.
Aug 10, 2008 | HP 640 Inkjet Fax Machine
Printing
other inks may be clogged, take out and put cartridges on paper towel, does it drain on the towel? if yes check the printhead.
Nov 14, 2007 | Brother IntelliFAX 1840C Plain Paper...
Receiving a fax
Brother web site has manual for download
check tel cord goes from wall to socket marked "line" on fax, with filter if DSL
check receive mode Auto or Manual to suit enviroment.
Check tel/fax mode
check distintive ring setting
Nov 08, 2007 | Brother IntelliFAX 1840C Plain Paper...
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
43 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
