Question about GE GSS22JFMWW Side by Side Refrigerator
Ge refrig. defrost prob.
Defrosts constantly replaced cntrl bd damper and temp. cntrl bd any help apprec. thanks
  • 74 Answers
Temp sensor at the top of the evaporator is the most likely fault but may be compounded by evap motor issues
Posted on Aug 28, 2008
Ge freezer temp changes from -3 to 44degs and the ice melts and runs on the floor. I replaced the main board about 2 yrs ago, help?
Self defrost mechanism appears to be ok sinc eyou can get down to -3 degrees. The culprit in this refrigerator is the temperature regulator or electronic thermostat in this box. It should not allow the temp to swing that drastically from one extreme to another.
Mar 17, 2015 | Refrigerators
Older ge refrig, freezer at top leaking water into refrigator compartment below. otherwise its working fine.
Its the defrost problem. The drain hole is clogged and water is leaking in fridge section instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/07/ge-refrig-freezer-at-top-leaking-water.html --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Refrigerators
Problems for Refrig. Kenmore Elite
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Nine y/o GE side by side not getting cold enough
More likely a defrost heater. Look inside the freezer at the back wall. Any frost there? If so, turn off refrig., unload freezer, take back panel off inside freezer, and use a hair dryer to melt off the frost. Replace the defrost heater located at the bottom of the frosted coils. (New heater may appear different than original, but instructions are included) If you don't have the defrost heater on hand, just manually defrosting the coils and re-starting the refrig will get is cooling again for at least a week before problem will re-occur. (this give you enough time to get the replacement part)
Mar 21, 2010 | Refrigerators
GE Monigram Ref, main food comparment stuck at 25 degrees
is your damper door between the freezer and refrige compartments opening and closing as you adjust the temp settings,they can become stuck open by ice build up,defrost the damper door and see if it closes then
Jan 16, 2010 | Refrigerators
Food in refrigerator is freezing
check the damper door between the freezer and refrigerator compartments,it most likely has frozen in the fully open position allowing cold air into refrige compartment all the time,you will see ice build up around the damper door unit,remove the door unit defrost,replace and then see if it moves when you change the refrige cold control
Jan 12, 2010 | GE Refrigerators
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
GE REFRIG. MODEL#TFX30PRYAA. side by side both
It sounds like your defrost control timer is working, but your defrost heater is most likely burnt out. It is a part number WR51X443
and is located behind the back wall inside the freezer. Turning the refrig off for 24 hours helped melt some of the accumulated frost, but not all. You will have to take that back cover off inside the freezer and melt all the frost with a hair blower, replace the defrost heater and reassemble.
Jul 01, 2009 | Refrigerators
Defrost not cycling
Hi. the Defrost timer assembly has failed. simply replacing this timer will fix the defrosting issue.
Concerning the refrigerators cold control. this is caused by a malfunctioning Temperature control assembly. simply replacing this device will fix the erratic cold control.
Now, i would inspect the compressor for its operational value before purchasing a temperature control assembly. If the compressor isn't cycling on and off and if it is making a very loud noise or pinging, this will confirm compressor failure. you will have to replace the compressor in this case.
If the compressor is coming on in a cycle and powering off without any abnormal noises, this will confirm temperature control failure. replace the temp control assembly in this case.
I will post the parts need below so that you may order the affected parts on line if you choose.
Defrost timer module.
Please rate and god bless:)
May 11, 2009 | GE Refrigerators
GE GSS22JFMWW Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
