Question about Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive
How do i unlock my 4gb usb drive - Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive
I cant remove write protective from my flash drive
Is there a slider type of switch that can be moved to the "unlocked" position? Or, how old is it? After a lot of usage, it becomes impossible to "write" to it, and so it becomes "read-only".
At 4GB in size, it only costs about $4 to replace it.
Mar 11, 2014 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
My imatinon nano usb 4gb now only 1 mb what should i do?
I'd go into disk manager, delete any partitions and reformat the flash drive.
Dec 23, 2012 | Imation 27102 4GB Nano USB 2.0 Flash Drive...
My 4gb memory card lockd
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
Jul 03, 2012 | SanDisk 4GB microSD High Capacity Memory...
My 2gb genx usb flash drive cannot be format it says write protect.any solution for this error?
Check if there is a small switch on the side of the USB drive (might show a lock and unlock symbol). If there is not and the drive came with no driover software and a utility to unlock, it is possibly faulty
Jan 09, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How do you unlock a verbatim 4 g pinstripe usb drive
right click on the drive and click format or re-format, this should erase everything on it and unlock it, but does not always work!
Dec 29, 2010 | Verbatim ® Store `n` Go USB Flash Drive,...
How can I remove the write proctection off of my dane elec 4gb thumb drive
There should be a physical little lock /unlock switch on the key drive somewhere. Its in the locked position. find it and switch it a few times then try again.
Sep 02, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
How to unlock a locked out flash drive
Hello.
Unfortunately, you cannot unlock a password-protected flash drive, unless you know the password.
If you just want to use the drive itself, format the flash drive. Of course, all the data will be wiped off,.
Hope this helps.
Aug 17, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
USB drive write protected ????
There is a small unlock tab. Please push it in right place to unlock
Jan 26, 2010 | Transcend (589307) Media
Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive Logo
Top Dane-Elec Computers & Internet Experts
Piyal Perera
Piyal Perera
woodzowl307
Robert Karst
Robert Karst
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
