Question about Nokia N72 Cellular Phone
SIR, SINCE LAST 3-4 DAYS, SUDDENLY MY N-72 GETS SWITCHED OFF. WHEN RESTART IT WORKS. SINCE MORNING SHOWING BATTERY LOW. WHEN I PUT FOR CHARGING, IT IS SHOWING NOT CHARGING, WHEREAS CHARGER IS O.K PLEASE ADVISE
    President:
  • Nokia Master
  • 1,932 Answers
This is the software problem.Please go to the nearest NOKIA CARE and they will reinstall the software and the mobile will be ok.
Thank You
Posted on Sep 30, 2010
Xpera arc totally dead after charging
mostly it seems like a software problem. Did you try restarting it by pressing VOLUME DOWN + POWER button??
if it's not working , then take it to a service center and re-flash the software once.
Nov 06, 2013 | Sony Ericsson Xperia LT15i Arc X12...
1972 Honda CB500 no electrical power
Hi, Minh before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda CB500 getting no power Motorcycle Forum
No electrical no idea
Honda CB500T Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Aug 18, 2013 | Honda CB 500 Motorcycles
Total battery power remaining: Unknown
Well you can try a system restore.
1.) start
2.) programs / accessories / system tools
3.) system restore
follow the on screen instructions too restore the computer to a few days before it started having problems.
Chances are that the battery is shot if system restore fails.
Mar 01, 2010 | Acer TravelMate 5720-6635 Notebook
My nokia 72 phone has suddenly switched off
Dear please reinstall its software. Problem will be quickly solved. Thanks
Jan 26, 2010 | Nokia N72 Cellular Phone
My mobill betry is so low and icant solution this problem so you can solv problem now thanks my name is piyushmistry &my cell no is 09824136819
Hello Sir, If the battery is showing low battery then you should charge it with its corresponding Charger. I think you are willing to tell that the Phone is showing low battery even after charging. If that is the case then there can be 2 causes :--- (1) The Phone's battery is not properly plugged in and thus can't properly retain the Charge which is supplied. In this case, try cleaning the Battery Contact, I mean the 3 Power pins and the 3 power slots. Use something like dry cloth. (2) The Battery is damped or defective. If damp then don't try to charge, it can sometimes explode. Kindly take it to a Service Center and get it repaired.
Also try changing the Battery.
Thank you Sir, Have a nice day.
Oct 12, 2009 | Samsung SGH-F250 Cell Phone
Battery charging problem nokia 3230
yes you have to..do get a genuine Nokia battery from an authorised dealer.regards!
Nov 04, 2008 | Nokia 3230
My white ipod wont turn on or charge
maybe when u insert the usb in the pc u just get it with out ejecting the usb because if not it has virus maybe ur pc is not protected i encouter that problem it did not on and play...
Jun 13, 2008 | Apple iPod nano
Motorola razr2 v9
it sounds like a one in a million defective battery goto service phone tech show them your receipt and have them replace this battery
May 28, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Battery low
u have 2 chenj ur mobile's battry connector.
Mar 09, 2008 | Nokia 3230
Nokia N72 Cellular Phone Logo
44 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
