Question about E-Machines Computers & Internet
Cd rom wil not open when i press on the device to open nothing happens
  • tobagogi Sep 30, 2010
    I will not do sucha thing this is a new machine and has been taken back four times for this problem
    and it happens all the time ....so which means i have 2 continue with this "pin thing:,,,I don't thik so
    it is new and should function like new I only had it since july 10 thanks anyway
    I am really pissed off at the whole matter
    Guru:
  • 1,481 Answers
Use a small pin bend it a little....and pull it out from the small gap on the side of the drive lid...do this when keep pressing the drive open button.....it may be struck....just try...
Posted on Sep 30, 2010
  • Suresh Ayyar Oct 01, 2010
    my advised was based on some assumptions....old drives give these kind of issues...and i myself use this technique to open the drive sometimes...and there is no harm in it also....but as u say it's NEW...then it should work like.... knife thru butter....if it's been take by the service personal 4 times then i guess there should not be any issue with the drive physically.....some issue on the motherboard SATA socket that connects the connector to the drive...... or the connector of the drive....or the power cable that connects the drive to the motherboard / power unit....
Cd rom will not open
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
If there is a small hole on the panel of your dvd drive push a straightened paper clip inside until you feel it press down this will open up the drive.
Mar 16, 2013 | eMachines EL1352G-01w (884483537679) PC...
Cd rom drive door keeps opening up when in, it won't start cd
Try to this. Start - Right Click My Computer - Properties - Hardware - Device
Manager - CDROM - Properties - Disable. See if it Stops then enable it again.
Look at cdrom button it might obstructed or pressed in, try pulling and pressing. Or it could be a program/driver problem. Try restoring your pc the day before it happen.
Sep 14, 2011 | E-Machines emachines (emachinees) CD-ROM...
My Dell Inspiron 9200 Laptop has a IDE\CDROM_NEC ND-6500A CD-ROM Drive has a driver problem. According to the troubleshooting report, the driver needs to be reinstalled. TROUBLESHOOTING REPORT Device...
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 12, 2011 | NEC ND-6500A DVD±RW Dual Layer Burner
My cd/dvd rom stopped working... you can hear it running for a min. or so then nothing... it wil not download my photos from my camera either... I Have a T3985 Emachine desk top ( DVD+/-RW )
hope this helps or
if this does not fix the problem might be a registry problem
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 09, 2011 | E-Machines emachines (emachinees) CD-ROM...
I cant get my cd rom to open.. and I even hit the reset buttom and it wont open at all.. I dont want to force it..what should I do
ok take a sharp niddle... now you wil find very small hole near the open button on drrive
Dont worry insert niddle in that hole
that wil work
and your CD ROM wil get open
Mar 06, 2010 | Dell 48X Half-Height Serial ATA Internal...
I put the cd rom into the drive and nothing happens. I go to click on the icon under my computer and it causes the window not to respond.
Confirm that the CD drive is not a CD-ROM dive and the CD you are trying to open is is not a DVD. CD-ROM drive wil not open a DVD ROM and in some cases will cause the system to stop responding if youtry to run it.
Jan 26, 2010 | The Learning Company Oregon Trail 5th...
The CD drawer doesn't open...I push the button and it sounds like it's going to pop the lil drawer open...nothing happens. Help pls...
take a paper clip and streighten it out in a long wire - you should see a hole in front of the cd rom by the drive bay press it in the hole and push the drive open
here is a video
http://www.youtube.com/watch?v=kscn5_XG2oE
Dec 27, 2009 | Compaq (120192-B21) CD-ROM Drive
Cd/rom not working
Try deleting it in the device manager and then reboot your computer to see if it will detect it, then when it asks, point it to the driver.
Oct 25, 2008 | Computers & Internet
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
CD ROM not working
OUR CD ROM WONT OPEN ON HP
Jun 10, 2008 | HP Computers & Internet
Computers & Internet Logo
41 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
