Question about Kenmore Vacuums
My Kenmore Quick Clean vac clogs at the top of cannister and does not let dirt to go to canister. After vacuum for few minutes have to stop empty before continuing to get rug clean. Is there anything that I can do to solve problem.
You need to own an air compressor,and blow out all vacuums ,after each use.
Posted on Sep 30, 2010
No suction in vaccum cleaner
Look for a clog somehere in the intake path, perhaps right at the top of the canister.
Feb 13, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Loss of suction
If it is running and you have no suction, there has to be a clog in the dirt path. To clear it, start at the head of the vacuum (where the dirt goes in) take apart or disconnect everything you can along this path until you arrive at the bag or cannister. Take pics with your cell phone so you can reassemble it. Hoses: run a broom handle through all hoses to assure they are clear. If you have a shop vac or similar, try applying vacuum to all parts of your disabled vacuum in reverse. Are there filters on your machine? Make sure they are clean. You probably don't have hoses connected, but if you do, check them as I said.
I pick up vacuums along the road all the time. Very few are more than a few months old. All of then have a clog in the hose or elsewhere in the dirt path. I clean the path and sell the vacs for a slightly discounted price. VERY rarely is it a motor problem.
I hope you find this comment helpful. Here they are in under 5 minutes. Thanks for using FixYa.com
Jun 27, 2011 | Kirby G5 Bagged Upright Vacuum
My kenmore quick clean vacuum cleaner has no suction. Just seems to blow the dirt out and away from the cleaner. The canister is empty and the filter is clean, so what's going on?
The hose or hoses are plugged...take all the hoses apart and stretch them out... run a stiff wire through them or something like a broom handle...you will find that they are full of dust and dirt inside...
heatman101
Apr 24, 2010 | Kenmore Quick Clean 30012 Vacuum
Kenmore vac won't shut off, blowing heavy air from vent
For the stack of problems you have, it sounds like it be best for you to ditch it and get a new vacuum. The heavy problem sounds like a motor issue. The burning smell is most likely from the belt being loose on the power head.
Economically, you should just get a new one instead of replacing the whole system guts
Aug 14, 2009 | Kenmore 25512/ 25513 Progressive Canister...
No suction
If the motor is running and is not full of dirt, and the hose is not plugged, the canister must be cracked or open somehow.
May 08, 2009 | Kenmore 22812 Bagged Canister Vacuum
Dirt Devil Extreme Quick Vac - Won't turn on
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
Mar 06, 2009 | Vacuums
Kenmore Quick Clean - how to remove dirt from cannister
this is the web site for Kenmore owners manuals
--->http://www.managemyhome.com/mmh/<---
Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Kenmore Quick Clean 30012 Vacuum
My central kenmore vacuum wont suction
Hello hdd85,
I think you answered your own question when you verified that all the vacuum outlets have vacuum on them and then after you hook up tyhe vac hose, you fail to get vacuum at the other end. I would say that based on your problem description, you have an obstruction in the hose. You may have afriend with an air compressor that you can try forcing air in one end to free up the clog but if that doesn't work, do you know anyone with a wet/dry utility vac that you can try using the vacuum or exaust side to free the hose up ? Lastly, if you know an electrician, they normally have 'snakes' used to fish wires thru wall cavities... If careful, that might get the clog out.. Hope that gives you soem ideas on how to resolve,,,,
Regards,
Rick
Jan 26, 2009 | Vacuums
Sounds funny/shutting off after few minutes
Yup! Clogged hose on the back of the cannister! Unit is designed to shut off for 30 minutes when this happens to protect your motor. Remove top of hose where debris enters the cannister through a filter above it, then remove the other end of the hose from the bottom of the back of the cannister, take it outside and use something long that'll fit inside the hose to force out all the clogged debris and hair through the top of the hose.
Oct 17, 2008 | Bissell LiftOff Revolution Pet Vac 37602...
We have a Kenmore Stylite Retrax vacuum cleaner, brand new. Suction is not working properly.
I actually pulled back my old vac after using this thing. Having said that I have played around with it and one quick cure is the remove or clean the little circle sponge filter at bottom. If you remove the canister and look at the bottom of vac you will see where the air travels down through a small circle. In there is a sponge filter that is probably clogged. Now Being frustrated, I just removed it and the vac sucks like crazy now. There are just way to many filters to worry about. As mentioned you need to clean the top main filiter, then the top sponge filter, and then dont froget there is alson one in the front of the machine (square paper filter) that catches dust leaving vac. These are on top of the little circle one that I removed, so I dont think it will be missed. Try and see what you think.
Apr 21, 2008 | Vacuums
Vacuums Logo
87 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
