I have on e vertical line on my plasma on the left hand side. Please help. I have a Samsung plasma.
    President:
  • 1,779 Answers
Check and clean the buffer board ribbon cable that corresponds to where the line is.be careful not to damage to connector. Your set will be scrap if you do. Not a simple task. I recommend taking it in and let a tech do it for you.
Posted on Sep 30, 2010
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
1 vertical black line on samsung plasma tv on left side (model # pn50a450p1dxza)
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily. Faults to Samaung Plasma TVs are given in detail.
Aug 19, 2012 | Samsung Pn50a450 Pn50a450p1dxza 50" 720p...
I have a permanent dark/black 4.5" wide vertical line on left side of plasma TV. It seems as if it is 4:3 display mode on left side only. Any help would greatly be appreciated. I have no problem changing...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER .
BUT IF OTHERWISE CHECK
x driver cables 10 ohm resistors have loose connections
Hope this will help...
Jun 14, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HPR-5052X Plasma issues. Recently started
If the picture os goint to lines right from the midpoint downward then most likely you will have to replace the lower y-buffer board part number BN96-02027A. The board is mounted on the left side of the plasma panel when you take the back off. The upper y-buffer board sounds like it is failing as well and this was a very common issue on the older Samsung plasmas. The part number for it is BN96-02026A. Please take a moment and rate my answer. Thanks...
Nov 26, 2009 | Televison & Video
2 BIG THICK LINES ON LEFT HAND SIDE OF THE SCREEN..
If the lines are vertical and go from one side of the TV to the other, it is most likely the scalar boards. There could be a loose connection from the PDP module (plasma panel) and the scalar boards. Otherwise, the scalar boards need to be replaced.
If the lines are horizontal, then the same thing as above except for the y-drives instead of the scalar boards.
Oct 05, 2009 | Samsung 50 in. Plasma TV
Samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Jul 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
My Samsung plasma TV display a vertical line right in the centre of the screen, anyone having the same problem and solved.?
This could just be a cable problem.
Remove the back cover and carefully unplug all the flat cable connections on the left hand side (8) check / clean connections and then plug them all back in again.
Jul 21, 2008 | Samsung PS42P2S 42 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
