Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Frigidaire water leaks
When the ice maker fills with water, the water dispenser in the door flows out water. Also, when you go to dispense water through the door, water fills the ice tray causing it to over flow. The water valve has been replaced, someone thought it might be cracked and allowing it to flow water unintentionally.
  • 828 Answers
I suspect that when the water valve was replaced, that the plug's were reversed that provide the power to the valve. Exchange the two plugs on the water valve and you may find the problem is fixed.
Posted on May 26, 2008
Water leaking from Icemaker fill tube near the back wall
It probably is not the water valve. More likely it is the ice maker itself. Nothing else in the machine controls the flow of water to the ice maker except the ice maker itself. It is recommended that both the ice maker and the water valve needs to be replaced when trouble such as this.
Dec 12, 2012 | Refrigerators
Ice maker is not making ice, but water from door dispenser flows normally. Ice in the tray (where it is made), but it won't dump into the holding tray. any solutions?
Greetings,
The first thing to check is the tube that puts water into the icemaker...this sometimes freezes up from a leaking water fill valve..if so, this blocks the water from filling the i/m....if its not frozen up and is clear(open) then your fill valve is bad or your icemaker module(if equipted) with that style...
Dec 14, 2010 | Frigidaire Refrigerators
Water dispenser in door
If the water is also going into the ice maker then the water inlet valve on the back where the water supply connects is bad. It's opening both valves or leaking across when the ice maker call for water. Does water go to the ice maker when you try the water dispenser. If not the wires on the valve may be on the wrong plugs. Swap them around and see what happens.
Jan 24, 2010 | Frigidaire FRS26R4A Side by Side...
Ice maker doesnt make ice
* Check the temperature setting
* Assure that there is enough room for air flow in the freezer or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condenser coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Aug 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Water to ice maker isn't filling tray.
what is the inside temperature in the freezer? it has to be below 17 degrees before the ice maker even try's to work
Dec 11, 2008 | Frigidaire FRS26R4A Side by Side...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Water dispenser spontaneously erupts when making ice
I had to fix a problem like this the other day you need a inlet solenoid
Aug 29, 2007 | Frigidaire FRS26KR4A Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
282 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
