Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Belkin54g wireless router
If im using wireless i cant play bingo or some other sites but if i disconnect wireless and hook straight into internet it works whats wrong with my wireless and can the problem be sorted without buying a different wireless router ???????????
    Genius:
  • 1,224 Answers
Its a belkin
its a static packet data router only so much info gets in before it can unload so it shuts down
get a streaming netgear router basically like a hooking direct to comp
Posted on Jun 02, 2008
Im using dell laptop winxp, I alredy connected to wifi access yet cant access internet connections. Pls help. Thank you
You can try other options such as these
1. Try disabling or uninstalling your Firewall / Antivirus 2. Uninstall your Wireless Application and use the wireless zero configuration on your computer 3. Try resetting your router to its factory defaults 4. Try hooking up a ethernet cable to the router see if your getting internet access.
Jul 22, 2011 | Internet Computers & Internet
Can i hook up my ps3 to a wireless laptop with an ethernet cable?
you can for the 360 go to ur network then i think properties then share network(on pc) its on youtube im not sure about ps3 i have wireless
Dec 14, 2009 | Sony Playstation 3 (PS3) Console
Laptop keeps disconecting from belkin54g dsl network (home)
Wireless connections are best when distances are short and there are no brick or thick walls interfering with the signal between the router and your laptop. Try the following test:
Start using the laptop from an open location that is close to the router. Monitor the signal strength as you walk away from the router. Go into other rooms, go upstairs, downstairs, etc, and you will most likely notice differences in signal strength depending on where you are, or how far you move. Of course, you will suffer frequent disconnections when the signal is at its weakest point, no matter what equipment you use, be it new or used.
Try locating the router in a way that your signal strength is strongest, without affecting the other computers. It's a trial and error thing.
One last thing you could do is to go to your wireless adaptor configuration settings and set the Roaming capability to agressive, and set the connectivity to distance, for higher performance.
Aug 19, 2009 | HP Pavilion dv4000 Notebook
My belkin54g router will connect to the internet fine and will browse the web but when i connect to MSN messenger it keeps booting me off of it and when i browse videos on Youtube they only download part...
Try to reset the factory settings on your Belkin54g Router, to make sure also that the Router is working is open the firmware on it. And setting up your internet connection properly. Good luck!
Jul 29, 2009 | Computers & Internet
Blocking sites
change the password
Apr 07, 2009 | Computers & Internet
Password for belkin54g
There is no default WEP / WPA key for belkin54g routers. The default password to access the setup is blank. Try going to 192.168.2.1 in internet explorer (where you would usually type the address of the site in), and see if you can find out the WEP / WPA Key.
Dec 24, 2008 | Computers & Internet
I am getting a connect to belkin54g mesg. when I have comcast service. Why?
This is a message from your router and not from comcast service.
Sep 25, 2008 | Computers & Internet
Wireless router
First make sure wireless is turned ON or enabled on the computer, then use the View Available Networks to connect to the your SSID or network name. IF you can connect to router then you should be able to surf Internet.
Jun 26, 2008 | NetGear WGR614/WG511 (wgr614nawg511nakit)...
I keep getting disconnected from xbox live
do you or a neighbor have a 2.4GHz wireless phone? If so, you'll lose your connection anytime someone calls in, and occasionally not have any ability to connect while the phone is being used.
Jun 20, 2008 | Linksys Wireless-G WRTP54G Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
70 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
