Question about Samsung Refrigerators
The fridge keeps leaking water underneath,the freezer part keeps iceing up down the bottom under the draws,the water is the main problem.
  • Samsung Master
  • 17,130 Answers
Water in the drain overflowing can be the reason for the water spilling,it can be the defrost overflow or the leak from the evaporator tubing's to the drain. So drain off and check perhaps more condensation is the result of the overflow.
The icing can be related to water formation from the food or leak from the evaporator, high frosting can blow the water inside the freezer.
So set the freezer temp a little lower so that the freezer shuts off than to make it run continuously.
Posted on Sep 30, 2010
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Sep 10, 2017 | Frigidaire Refrigerators
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Leak!
Hi as well,
With no other source of water for the leak, this has to be your defrost water, and it does sound like the drain to the evaporator pan is clogged.
The pan will be underneath the unit -- should be a panel you can remove along the bottom edge to access the pan.
If you trace the drain from the bottom of the unit back into the fridge, you can find where the water is supposed to drain into the pan. This is apparently clogged.
May 29, 2009 | Zanussi ZEBF250W Bottom Freezer...
Zanussi fridge /freezer
the drain located under the evap. maybe stopped up pour some boiling hot water into it and see if it drains underneath into the drain pan
May 06, 2009 | Zanussi ZEBF250W Bottom Freezer...
Frigidiare PLHS39EESS9 Ice build up in bottom of Freezer
I had the same problem with my Jenn-air side-by-side
Your freezer has a defrost cycle and when the freezer temp is set too cold, your drainage pan and tube freezes up (behind the back panels in the freezer) and when that gets full it spills over too the bottom of the fridge and keeps building up until you notice.
  • Un-plug fridge and put your food in coolers or another fridge.
  • Defrost the freezer, remove the ice from the bottom.
  • Remove the back panel/s (in the freezer).
  • Check the drainage pan. If it is iced up, you'll have to carefully remove the ice and check the drainage hole.
  • If the hole is iced up, so is the first 1-2 inches of the plastic tube leading to the main drainage pan behind and under the fridge.
  • You can use a hair drier to speed up defrost.
  • To defrost the hole and tube I used round ended metal (nut pics or beater attachment ends- avoid sharp objects) heated up in boiling water and gently forced down into the hole and tube until defrosted.
  • Check flow(by pouring warm water) down and looking behind and under fridge(with flashlight) to see if flowing into main drainage pan.
  • Turn up your freezer temp and check with a thermometer. Your freezer temp was probably set too cold
Mine is going on 5 months with no problem. If this continues, it might be the defroster.
Good Luck!
Mar 22, 2009 | Frigidaire PLHS39EESS Stainless Steel
Jenn air side by side leaking water
to allow your fridge/freezer to be ice free a timed defrost phase apxx every 7 to 10 hrs occurres whe the ice is drefrosted the water shoud go via a collection tray to the top af the compressor to keep it cool the tray is situated at the bottom of the freezer side behind the panel youll find is probally blocked and the water is overflowing to the front instead of going the correct way if you tecn minded unplugh the appliance remuve the pabel and unblock the drain tray the panel is inside the freezer torward the bottom
Nov 13, 2008 | Jenn-Air JCD2389G Side by Side...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Ice in Refrigerator Section
there are 2 possibilities. first the drain is blocked causing water to overflow from the defrost water gulley at the bottom rear of the inside of the fridge. this can form ice as it is close to the division between fridge and freezer. second, the .fault of ice growth can be caused by breakdown of the cabinet insulation. of the two, the first is the moree likely. to test drain is cloear, pour a little water down the drain. if it does'nt flow freely, push something flexible down the drain hole till blockage is clear
Apr 14, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
250 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
