Question about Samsung PN50C450 50 in. TV
I have to unplug it because it sounds like its turning on but it dont. It makes that turning on sound over and over again
  • Samsung Master
  • 17,130 Answers
You mean to say that the set is shunting which can be arelative power based issue wherein the power is used by a section to exceed and the power trips only to give it back again.
The circuit must be checked for the voltage variation specially in the output boards, detach off the heating components to see if the shunting stabilises. The fault can be identified and replaced, but check from sections to sections in disconnection.
Posted on Sep 30, 2010
Yamaha dgx 500 keyboard
Unplug and leave it unplugged for a while and then make sure the plug is nice and secure on both ends and try again
Jul 28, 2013 | Music
2002 dodge intrepid,fans dont kicks on.unplug the relay while car is running it work.turn the car of,turn it back it dont kicks on again. whats the problem.
sounds like maybe a breaker, over heating, something is disconnecting and when you turn the key off it resets, then does it all over again .
check breakers,(if equiped) shorts,fan motors going bad pulling to much juice,?
I WOULD check the relay
Mar 28, 2011 | Refrigerators
Heater makes noise humming sound is this normal i replaced 3 8ftrs they make the humming sound the smaller 6ftrs and3 ftrs dont make a sound ?????
This is perfectly normal. This is caused by the heating elements sagging over time. In my years of doing this I have seen this many times before. If yours is new then it may just be a mount loose. Turn it off and check the mounts on in inside of the unit. UNPLUG IT FIRST!!!
Jan 26, 2011 | Fahrenheat Electric Convector Baseboard...
I have Amana heat pump, I dont know why it does
sounds like your resetting the compressor its going off on high head pressure. check and make sure the condensor coils are clean. and that the fan is running properly.
May 10, 2010 | Amana PTH123B25AJ Heat Pump Air...
No sound from monitor
Try to re-install your audio driver !! Also go to add and remove and remove media player and then go and re-install windows media player again( probably a newer version ) should work!!! swampratt200 AAAEEE!!!!!
Jul 21, 2009 | HP Compaq WF1907 Monitor
No sound
unplug spkr from amp and leave rca and turn if this dont happen again check you spk
if it does happen again unplug rca and turn on and if this happen your amp may be bad
May 17, 2009 | SPL Audio Phantom DK2-1000 Car Amp
Turning signal makes grinding noise when turned on.
this is the flasher unplug it and go get a new one
Jun 11, 2008 | 1995 Mercury Sable
Sound
make sure your sound is connected,the wires to there correct location on computer.make sure monitor connections are correct and secure ,(tight)then reboot computer ,if know sound, then roll back sound drivers in device manager or re install sound drivers and reboot again,see if this correct's your sound problem
Sep 07, 2007 | ViewSonic EA771 Monitor
No Sound
well, if it powers up, youve still have hope// check and see if you can see a fuse holder at back of stereo... or go to a radio shack or electronis place and get whats called 'contact cleaner' ( may go by a different name, make SURE you know that the salesperson knows what your talking about..PS.you dont have to buy the pricey stuff, but dont get the cheapest either.) then UNPLUG stereo, make sure its not hot ( dont have it on for a long time before working on it) then pull out the knobs on the front ( the volume,left/right,etc) spray a LITTLE bit into the stereo where the plugs go.dont drench it, a little goes a long way) after spreying it in, turn the knob back and forth so it gets to all the points.... make SURE its dry before plugging it back in, you can tell if you see any moisture where you sprayed.( another reason, not to spray much) i usually let my stereo and tvs dry over night before trying them.while your waiting, may as well take a cloth and clean the face, get any cruddies off... good luck
Mar 12, 2007 | Kenwood VR-405 Receiver
Samsung PN50C450 50 in. TV Logo
135 people viewed this question
Jerry Greenberg
Jerry Greenberg
