Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
I have a Badger 5 1/2 HP and it makes a humming sound when I turn the on switch. I've tried the reset button and it doesn't help. It doesn't appear anything is stuck. Any advice? Thanks!
  • Ace Hardware Master
  • 43,501 Answers
Hi, Sounds like the motor just died
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Posted on Sep 30, 2010
Testimonial: "Thanks for your quick response! My allen wrench was too small but I used the end of a screwdriver and worked it back and forth and it worked! Thanks!"
Badger 5-81 motor buzzing, blades spinning, won't grind
Replace the whole thing. They are not that expensive and are easy to replace. The issue could be bad motor part or the shaft came loose from the grinding disk.
Jul 09, 2017 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal hums, but doesn't work. blades turn freely, as well asthe motor with a wrench- with no pressure?
Copy following link for disposal troubleshoot, and replacement tips:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Sounds like disposal motor has overheated and shorted.
Fortunately today's disposals are fully contained, and did not cause fire.
Replace disposal.
Mar 16, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger 5 1/2 HP garbage disposal. When I turn on the power switch it just makes a humming sound but doesn't engage. Is there a reset button somewhere on the unit that might need a...
There should be a reset button (circuit breaker) on the bottom of the unit. It sounds more like the blades are stuck. Pull the plug on the unit and use an allen wrench on the manual blade turner on the bottom of the unit. If the blades are stuck, you will have to try and loosen them with the allen wrench. If you do get them loose, the question then is what was holding them. Could be debris in the ISE or something broken like a blade. Keep the unit unplugged when working on it.
Sep 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposle makes a humming noise when turned on. InSinkErator Badger 5, 1/2 HP Garbage Disposal
Did you also hear any clattering sounds when it started? If so, it is rotating. If not then this hum is the motor in the lock rotor stage. Did you place garbage in it yet? Always run cool water in it when starting it.
May 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: It hums but doesn't work. The wrench moves freely ...
If the blades move freely with the wrench and stick and motor hums then it sounds like it is time to replace the unit. Have you tried the reset switch? If it is humming than it is probably not tripped but worth a try. Hope this helps.
May 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: Just hums and won't run, even after assuring that ...
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator badger 5 doesnt turn on
Make sure that the fuse/breaker is not blown/tripped You could take a voltmeter and check for voltage at the unit. Hope this helps
Sep 28, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
567 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
