Question about GE Heating & Cooling
Boult a 8.000 btu air on 5-2-08 have to keep it on 64 to stay desently cool and now it trows reset button and have to push reset a couple times before it comes back on
  • 828 Answers
Check the voltage supplying the A/C and insure it is in the nameplate range.
Posted on May 25, 2008
Remove exhaust hose
U need that hose to direct the warm air outside the area to be cooled. If you remove it, the hot exhaust will stay in the room being cooled and negate the cold air being directed into the room.
That is why regular room AC units are mounted on window sill. Cold air in, hot air out.
Oct 08, 2015 | Haier Commercial Cool 8,000 BTU Portable...
My Haier HPY08XCM 8,000 BTU Portable Air wont cool. How do I troubleshoot?
  1. HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015
    ? 1:59
    www.youtube.com/watch?v=kx1_1q4ByC8
    Apr 19, 2015 - Uploaded by Denada Pinoy
    In this video I review the HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015. ... No comments to display ... CommercialCool 12,000 BTU Portable Air Conditioner with Timer with Dan Hughes - Duration: 9:24. by QVC ...
Jul 21, 2015 | Haier HPY08XCM 8,000 BTU Portable Air...
Excess water prodution in portable 14000 BTU unit. See below
all a/c units remove moisture from air with cooling coil being cold and room air blowing across coil - depends how humid it is - i have used several different portable units and this seems to be a common problem if it is humid
Jul 03, 2014 | Commercial-Cool 8,000 BTU Portable Air...
How doest it drain on air conditioner 25379081
most window units use the condensation to help cool the condensor. some days little to any drainage. a slinger ring on outsde blade side throws water on coil and evaporates.
Jun 29, 2014 | Kenmore 8,000 Btu Room Air Conditioner...
Unit has been working but suddenly stopped and won't turn on. what is the problem?
Look for a little compartment of slot for a fuse or a reset button. Do you have the owners manual? That might give you some solutions as well.
Jun 17, 2014 | Haier Commercial Cool 8,000 BTU Portable...
Where is the temp sensor and coil on a kenmore 253.79081?
you can try to remove the unit and clean it. front coil and back coil.
Jun 02, 2014 | Kenmore 8,000 Btu Room Air Conditioner...
Fan is making rubbing noise
Time to have an expert look at it as it might be a fan about to fail or something worse.
Aug 30, 2012 | Haier 8,000-BTU Commercial Cool Portable...
Air Conditioning broken - fan still works
Probably a control board failure. If the modes don't work and the fan auto/on works, I'd say the circuit board has failed. Does the fan turn on when cool is selected? If not, 99% sure it's the board. If it does, it's probably a compressor component issue. Window units are considered throw aways.
Aug 31, 2017 | GE Heating & Cooling
How much horsepower of aircon do i need for 20sq m space of area?
IIT DEPEND ON HOW MUCH COOL DO YOU LIKE 5,000 B.T.U. WILL COOL A SMALL ROOM BUT AN 8,000 WILL KEEP IT COOL.
Nov 26, 2009 | Samsung Heating & Cooling
Unit will not turn on when Electric current is on
There is no power to the unit, the power is fed from a spur switch which is usually placed next to the unit, it comes with a fuse. The spur switch is also fed from the MCB or the consumer unit which contains all the fuses supplying power to the appliances in the house.
Usually they are clearly marked, look for the one that supplies power to the air conditioner and check whether the circuit breaker is ON or OFF. If is off switch it on and if the breaker stays on, you have power and you can try switching on your unit and hopefully if there is no fault on the unit it should start up.
On the other hand if the circuit breaker doesn't stays on and it trips back automatically, am afriad there is an earth fault in the unit you need to call an experct to come and check the unit.
If the Breker stays on but the unit does not power up, check the fuse in the switch spur and if you dont have the test instrument to check the fuse, just replace it with a new one with the same amps rating that you are 100% sure that its working.Remember to press the reset button which is the safety device between the power cord and the unit.
Good luck.
Aug 31, 2009 | Haier Heating & Cooling
Heating & Cooling Logo
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
