Question about Comfort-Aire CS-101A Air Conditioner
There is no power to AC when I plug it in. I checked the fuse box and everything seems to be working.
  • Comfort-Aire Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 30, 2010
My headlights, horn, panel lights, electric door locks, and radio quit working, all at the same time.
  • JUST WENT THROUGHT THIS WITH MY DAUGHTERS CAR!! WOW WAS GONNA RIP EVERYTHING OUT , I CHECKED FUES!! ALL GOOD, SHE AHD NO HEADLIGHTS, TAIL LIGHTS, POWER LOCKS, RADIO OR BRAKE LIGHT OR HORN, SO I GOT TO THINKING THAT THIS JUST CANT BE A BAD GROUND, BUT DIDNT SEEM RIGHT. SO I GOT A BOOK TO LOOK AT THE WIRING, ACTUALLY I USED THE 1994 VERSION AND IN THAT THERE ARE 2 POSITIVE WIRES COMING FROM THE BATTERY, WELL ONE GOES TO STARTER AND FUSIABLE LINKS THE OTHER GOES TO THE FUSE BOX THAT SUPPLIES POWER TO ALL THAT WE NOT WORKING, WELL FOLLOW THE 2ND POWER LINE FROM THE BATTERY THAT GOES TO FUSE BOX, WELL AS YOU START TO FOLLOW IT THERE IS A PLUG THAT JOINS THE WIRE TO THE WIRE THAT GOES TO FUSE BOX, UNPLUG TURNS HEADLIGHTS ON ANT REPLUG BACK IN. IT WASNT MAKING A CONNECTION ANYMORE!!!
    Nov 17, 2013
    FRED THE REASON I SAID TURN THE LIGHTS ON THEN REPLUG IN , IS THAT YOU WILL SEE THE LIGHTS COME ON AND HEAR THE CHIME OF LEAVING THE LIGHTS ON WHEN YOU PLUG BACK IN. WHEN I LOOKED AT THE DIAGRAM IS WHEN I REALIZED THAT THAT 2ND WIRE SUPPLIED THE POWER TO THE FUSE BOX FUSES THAT IN TURN WOULD OPERATE EVERYTHING THAT WASNT WORKING. WHE YOU UNPLUG THAT PLUG, ITS ABOUT THE SIZE OF YOUR PALM, LOOK AT THE CONTACTS INSIDE AND MAKE SURE THEY ARE NOT CORODE. IF SO BUY SOME CLEANER AND APPLY. I HAD UNPLUGGED THIS PLUG ABOUT 6 MONTHS AGO WHEN REPLAVING THE BATTER AND HAD PUT THE GOOP STUFF IN THERE FOR THAT REASON. JUST THINK IF ALL THAT STUFF IS NOT WORKING AND YOUR FUSES ARE GOOD? YOU JUST AINT GETTING POWER TO THE FUSE BOX WHICH THEN THERE IS NO POWER TO EACH ITEM, HOPE THIS HELPS ANY QUESTIONS FEEL FREE, SINCE I SEE THIS IS AA BIG PROBLEM YET NO ONE ANSERED WITHA FIX
    Nov 17, 2013
Jan 17, 2013 | 1995 Oldsmobile Cutlass Ciera
1994 chevy astro cluster problems
I would check the circuits from the ignition switch next. Sounds like not everything is getting power from the key.
Aug 28, 2012 | 1994 Chevrolet Astro
My AC stop working the car is 2009 infiniti FX35 what could be the problem mechanical or electrical
both check ac compressor first pull plug from top of compressor right behind pulley check for power if power check freon level if freon level full see if clutch on compressor engages when ac turned on if so then most likley expansion valve if freon level low have a leak test using uv dye available at most parts stores to find leak , if no power back trace line from compressor to fuse box and from fuse box to control panel
Jul 24, 2012 | Air Conditioning and Heat for Infiniti...
I have a 2006 ford explorer, with dual and elect contols, the a/c went out meaning no clutch, checked freon level its ok, checked clutch gap, checked and put all new relays and checked the diode and all...
You may check your fuses and relays you have a AC clutch relay in the battery box that has two fuses feeding it they are also in the fuse box under hood fuses 48 and 24 bothy 10amp fuses. fuse 24 is hot all the time and fuse 48 is only hot when car is running
May 23, 2011 | 2005 Ford Freestyle
My rear AC blower dosent work. I dont seem to
Thanks for using Fixya!
check the wire terminals from the fan motor, its possible that they are loose. Also check the relays if they are good. Just swap out the other relays to test if it will work. These relays can be found in the fuse box under the dash or under the hood.
Have a great day.
- HotRatchet
Jul 26, 2009 | 2003 Chevrolet Suburban 1500
No power for AC compressor
try removing the plug off the low pressure switch on the accumalator plug a paper clip into the plug and turn ac on if it comes on then your low pressure switch is bad or your low on refigerant.
May 28, 2009 | 2000 Chevrolet S-10
My driver side power seats and side power mirrors don't work!
sounds like a bad fuse, have a look at your manual and see which fuse controls those parts, they are most likely on the same fuse, the fuse box may also say which fuse is for what, If the fuse in the first box doesn't fix it, try a new fuse in the box under the hood, let me know how this goes, you may also have corrosion in a wire but check the fuses first.
Jul 01, 2008 | 2003 Ford Windstar
Power Failure
Check the output from the AC Adapter first. If no good, battery not charging/dead so nothing works. If good, camera needs service - could be anything. There is probably at least one surface mount fuse.
Aug 20, 2006 | Canon ZR60 Mini DV Digital Camcorder
Comfort-Aire CS-101A Air Conditioner Logo
87 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Cesar Quant
Cesar Quant
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
