Question about Maytag MAV6200 Top Load Washer
Maytag Mav6200aww making a load grinding like noise seems if its not fully engage into gear, or if its slipping in and out of gear in wash and spin cycle and agitates slow. ok in rinse cycle. I have the whole unit apart (transmission) with the drive pully attach to shaft. when i spin it clockwise the top shaft agitates and when i spin it counter clockwise the brake disengages. i tried to spin it clockwise to check once more the top doesnt agitate now. upper shaft doesnt move at all. been on this project for days now.
  • 11 Answers
SOURCE: Agitator not working on Maytag PAV2300
Sorry to be the bearer of bad news, but the transmission in your unit is bad,it has internal gears and the ones involved in the agitation are broke or bad, to replace the transmision is a lengthy process, your best bet is to just scrap it and get a new washer. I don't know if you know this but maytag company is no longer in business. They were purchased by Whirlpool back in November of 2006. One of the reasons is all the poor quality of their appliances. I am a technician that has been doing this for 15 years. The best unit I have seen to date is the Whirlpool Duet. I hardly ever have to work on them. Sorry for the bad news. Hope this helps.
Posted on May 20, 2007
  • 87 Answers
SOURCE: Correction! Maytag would not spin
You have a bad transmission.
Posted on Jun 08, 2007
Cyril J
  • 45 Answers
SOURCE: Maytag Atlantis Washer - MAV6200AWW
bolt has 1/2inch head but dont know the thread size is an orderable part 3 to 5 dollors, may not agitate since agitator not on shft to turn
Posted on May 16, 2008
SOURCE: agitator slipping
change your agitator dogs in agitator
Posted on Nov 14, 2008
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
Maytag washer mah9700 makes grinding noise and wont engage
take it its a top loader gear box suss if front loader check bearings
Mar 02, 2015 | Maytag Washing Machines
My LG Front Load washing machine is making a grinding noise on spin cycle I believe it is coming from the motor
Hello. The noise you are hearing on spin is a failed basket support bearing. Depending on the model, you are looking at a cost of a professional to repair it of around $400+. If you do it yourself, around $200. This is a common failure on LG washers.
Apr 28, 2014 | LG WM2487H Front Load Washer
WHen under load the motor revs up and it seems that the Clutch is slipping, it has 100000miles and I suspecting the clutch or the high / low range might be messed up, its a 4 plus 3 manuel transmission.
If it feels like the clutch is slipping, chances are it is. If there was a problem in any component that has internal gears, you would have grinding noises. Gears cannot slip. As the clutch wears more you may hear grinding when you try to change gears but that is because the clutch won't fully disengage so the gears are spinning too fast to shift properly. Before that happens, have the clutch replaced.
Aug 02, 2011 | Chevrolet Corvette Cars & Trucks
Maytag Atlantis washer. Washer makes noise that approaches grinding, and the agitator doesn't spin. Rather, isn't connected to the motor. Spins semi-freely by hand, with a rough motion and noise
Your unit is gear driven and is contained in a mechanism enclosure.The roughness your feeling when turning it are the worn-out gears.One cause is it might have ran out or dried out of gear lubricant.The motor drives a belt to run the gears so the motors are running fine.Your gear box is the problem.
Dec 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Spins but does not agitate
this unit has a berring problem the parts come in a kit not an easy doit yourselfer you also need special tools
Aug 09, 2009 | Maytag PAV2300 Top Load Washer
Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
60 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
