Question about eMachines ET183101 (PTNB602001) PC Desktop
I have a eMachines ET1831-01 but is not powering on why ??
    Guru:
  • 1,481 Answers
Power unit inside is out....
Posted on Sep 30, 2010
4 Suggested Answers
computerdeb
  • 323 Answers
SOURCE: my new emachines pc won't burn cds
Looks like your maching used DVD +R disks and that your burning software is Nero. Also, once in nero, check in tools and make sure that the right drive is selected. Hope this helps.
Posted on Dec 30, 2009
SOURCE: I am about to buy a graphics card and I want to
Check your power supply if it at least 300 watts you should be OK. But some need like 500 watts, so.. Also try and get a card that's not too hard on the system, look for a low Current draw device. & check if you can upgrade your Power Supply
Posted on Feb 06, 2010
paul4265
  • 592 Answers
SOURCE: I just want to know
First, yes, you can upgrade to a dual core pentium 2.93 GHZ..model E6500
as for video, yes, you can use a 2.0 pci-e video card as long as it is a 1x or a 16x standard. Those are the only standards supported by your computer, so if it is a pci-e 4x then it won't work, at least not for long...incompatible bus architecture.
I hope this helps !
Posted on Jan 04, 2011
Webcamera no working acer emachines e727 for windows7 pc
Kindly perform the below steps:
- Remove the battery and Power adapter
- Press and hold the power button for 30-45 seconds (with battery and power still removed)
- Insert just the battery and attempt to boot the laptop.
After the laptop booted go to the eMachine/Gateway Support site and download the webcam driver and software.
http://www.driverscape.com/manufacturers/emachines/laptops-desktops/emachines-e727/3265
Mar 06, 2015 | Acer Aspire Computers & Internet
Power cord on motherboard
Hello, The power to your motherboard is coming from your power supply if it is bad you will have to get another emachine power supply, for emachines, only emachine parts work.
Mar 01, 2014 | E-Machines eMachines Desktop PC
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No power
A) Power On switch is no good
B) Power Supply is no good
Do you wish to perform the simple test, to see if the problem is the Power On switch, or Power Supply?
If so post back in a Comment.
Also, IS it an eMachines ET1161-07 Desktop PC?
Don't want to 'rattle my lips off', if it's a different computer.
http://www.directron.com/atxswitch.html
Post back in a Comment.
Regards,
joecoolvette
Feb 10, 2013 | eMachines ET1161-07 Desktop PC
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
My brand new emachines el1352-03 doesn't turn on. Everything is plugged in.
try a differant socket or take it back to the shop where you purchased it.
Oct 06, 2010 | eMachines EL135203 PC Desktop
Emachines t5230 & no power Working fine one day and then no power the next?
Your eMachines features the cheapest power supply in the industry. I have personally replaced 6 of these. You can replace it with a factory unit for $20 or go to your local compter shop, and get a $40 unit that will last until you need a new computer.
( It says... 480Ws but I dont believe it )
$20:
http://www.cputopia.com/emachine-480w-t-series-t5230.html
Oct 05, 2009 | Gateway Computers & Internet
I have emachine w3400 not powering . plz help
I found this right on this website, hope it works!
As for the fans, make sure your connections are tight and in the proper sockets.
Jul 09, 2009 | AMD eMachines Desktop System w/ 17'' CRT...
MY BROTHER JUST GAVE ME THIS MOTHERBOARD FOR MY EMACHINE AND SAID IT CAME OUT OF AN EMACHINE, WHAT POWER SUPPLY DO i NEED TO INSTALL? Intel D845EPI Motherboard
i have seen those in some emachines but the original power supply stinks the processor needs a power supplie the has at least 300 watts but 400 plus is a better choice depending on which emachine case to have it might need ti have the case modded to fit a larger power supplie some emachine case have a plate mounted the allows both power supplie type to be used the small power supplies are garbage so go with the larger p4 power supplie most all should be able to be modded to fit in you case. Just remember the more power in mean the more power out.
Jun 10, 2009 | Intel Computers & Internet
2 emachines won't boot
Are you attaching them properly
if so then it is something other then power supply
something has caused both power supplies to blow
have you installed anything in the first emachine you talk about
Jan 17, 2009 | E-Machines eMachines Refurbished EMA...
eMachines ET183101 (PTNB602001) PC Desktop Logo
177 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
