LG WF-T8501TP. Top loading washer is not draining. It's full of dirty water.
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Posted on Sep 02, 2008
  • 4 Answers
SOURCE: draining extra water
Cut off the zip tie that holds the drain tube. Bring the drain tube as close to the ground as possible and siphon out the water - yes, that means sucking on that hose. Have a bowl handy to collect the water, or do it somewhere you don't mind getting wet. Just keep the end of the hose lower than the basin of water and you should have no problems.
Posted on Jan 22, 2009
ginko
  • 19396 Answers
SOURCE: water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Posted on May 21, 2009
  • 82 Answers
SOURCE: how do you drain the drain pump in lg front load
There is a small panel on the bottom left front of the washer with a tab on the top middle holding it onto the front of the washer. depress this tab with a small flathead screwdriver and the panel will open downward. You will now see a small round black piece on the left with a flat screw head on it, about an inch in diameter. unscrew this about a quarter of a turn and it will come out with a small hose attached. This is connected to the drain pump. Have a shop vac ready, pull the black plug out of the hose and this will drain the pump. The larger round piece on the right, about 3 inches in diameter is your drain pump. After draining all the water unscrew it with your hand. When you get this out it will have a screen attached which needs to be cleaned at least once a year.
Please rate this post. Thank You.
Posted on Jan 22, 2010
heatman101
  • 43501 Answers
SOURCE: Washer will not drain or spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 08, 2010
Lg intellowasher wf t8501tp
My washer WF-T8501tp shows a PE error code.
Can anyone tell me what's wrong with it
Nov 17, 2013 | Washing Machines
Wash a sheep skin cover now the machine will not drain water as it usually did...it is an LG WF-T7016PP
The hose from the tub to the pump or from the pump to the drain hose is blocked, remove and clear blockage.
Aug 19, 2013 | LG WFT1071TP Top Load Washer
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
My lg WF-T552TH washing machine will not drain the water during a cycle just wondering how i can fix it??
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 25, 2010 | LG WFT1071TP Top Load Washer
LG washer Model wf-t6517te not draining water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Aug 19, 2010 | LG WFT1071TP Top Load Washer
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
149 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
