Question about E-Machines eMachines Desktop PC
My computer has a password on it when you hit the f2 button. How do I retrieve the password
    Problem Solver:
  • 9 Answers
If you often change your Windows password or your memory isn't good, it is normal that you forget the password. To help you remember, or on the lowest to help you be in control and know your password, why do not you obtain a software program plan that will reset the password for you? The software program plan is capable of resetting and positively removing the more mature password in purchase for you personally for getting in a location to available your operator account. Why do not you consider a glance at this software program program? Please visit: http://www.passwordseeker.com
Posted on Mar 07, 2012
  • 707 Answers
Backdoor Passwords READ COMPLETELY!!
Many BIOS manufacturers have provided backdoor passwords that can be used to access the BIOS setup in the event you have lost your password. These passwords are case sensitive, so you may wish to try a variety of combinations.
WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords.
Award BIOS backdoor passwords:ALFAROME BIOSTAR KDD ZAAADA
ALLy CONCAT Lkwpeter ZBAAACA
aLLy CONDO LKWPETER ZJAAADC
aLLY Condo PINT 01322222
ALLY d8on pint 589589
aPAf djonet SER 589721
_award HLT SKY_FOX 595595
AWARD_SW J64 SYXZ 598598
AWARD?SW J256 syxz
AWARD SW J262 shift + syxz
AWARD PW j332 TTPTHA
AWKWARD j322
awkward
AMI BIOS Backdoor Passwords:AMI BIOS PASSWORD HEWITT RAND
AMI?SW AMI_SW LKWPETER CONDO
Phoenix BIOS Backdoor Passwords:phoenix PHOENIX CMOS BIOS
Misc. Common PasswordsALFAROME BIOSTAR biostar biosstar
CMOS cmos LKWPETER lkwpeter
setup SETUP Syxz Wodj
Other BIOS Passwords by ManufacturerManufacturer Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
Toshiba BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
IBM Aptiva BIOS
Press both mouse buttons repeatedly during the boot
Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop.
Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time.
Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system.
Hope it helps.
If this helps you resolve your problem, please
consider giving me a good rating .It will help me
as well. Thank you.
Posted on Oct 29, 2010
Verifone vx520 "Power Failure Recovery"
At the sales screen hit F2 & F4 together password is 1 Alpha Alpha 66831.
Then hit the button under the arrow on the left of the screen one time.
choose flash files the clear all files password again same as above.
Then clear Ram files clear all files and confirm and then you are on easy street.
Apr 29, 2017 | VeriFone Computers & Internet
Tip
Toshiba Laptop BIOS Password Removal
<span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
on Jun 09, 2011 | Computers & Internet
My Hdd is locked on my Dell XT2 I have the password but I cant find where to put in the Password
Restart the computer and tap F2 key during POST to enter System Setup (BIOS). This should prompt for the Hard Drive (HDD) or BIOS password. Knowledge Base
This should help.
While the computer is powering up keep tapping f2.
Turn it off. Press the power button again and keep hitting f2.
Aug 11, 2016 | Dell Latitude XT2 Tablet PC
Remove hdd password
You can change it but not 'remove' it. Simplest is to use '00000' as the default password.
Instructions
1 Shut down your computer.
2 Press the power button on your computer. While it is booting, press F2 repeatedly (do not just hold it down) until you arrive at a system screen showing a series of
options. This screen is called the BIOS Setup.
How to change the password on a Dell computer hard drive
Password Vault
Secure, centralized password vault for enterprises. Try now. manageengine.com/PasswordManagerPro
3 Use the down arrow key on your keyboard to scroll down to "Security" in the left-hand column.
4 Arrow right to display a sub-menu under Security in the left-hand column.
5 Arrow down to "Internal HD PW" in the left-hand column. (That stands for Internal Hard Drive Password.)
6 Delete the old password (if any) and, in the same box, enter a new password of at least four characters in length in the main screen at right.
7 Write the password down and keep it in a safe place.
8 Hit Enter.
9 Hit the Escape button on your keyboard to exit the Internal HD PW menu, then hit Escape again to proceed to the Exit screen of the BIOS Setup.
10 Arrow right to save the changes you made to the password, then hit Enter on your keyboard to exit the BIOS Setup.
11 Restart your computer and use the password you created in the BIOS Setup to gain access to your hard drive.
Apr 17, 2014 | Dell Dimension Computers & Internet
I have forgotten my user name and pass word for luminosity, I have change carrriers from comcast to frontier
Every time you choose to save a password in an application or on a Web site, the password data is stored in a secure location on your computer.
If you are an administrator, you can access the password data and retrieve a list of passwords that have been used on your computer.
Password data is stored in different ways on PC and MacIntosh computers, but the information is accessible on both types of systems.
Log on to your PC computer with an administrator account.
Open the "Start" menu and click on the "Run" button.
Type "keymgr.dll" into the text box and hit "Enter."
The Key Manager utility program will launch and display a list of passwords used on the computer.
Highlight the password item you want more information about.
Click on the "Properties" button on the right side of the window to view more information about the selected password item.
The pop-up window will display the username, password and server address for the selected item.
Mac Instructions
Log on to your MacIntosh computer with an administrator account.
Open a new "Finder" window by clicking on the icon in the dock.
Go to the "Utilities" folder in the "Applications" section of the Mac hard drive.
Double-click on the "Keychain Access" icon to launch the utility program.
A list of all the passwords used on your computer will be displayed.
Highlight a password item and click on the "i" button at the bottom of the window to view more information about it.
Hope this helps.
Save and Retrieve Passwords in Google Chrome
The Google Chrome Web browser includes a variety of features for your surfing needs. Standard features include tabs, JavaScript, cookies and extension support.
Many sites require a user name and password to obtain access to special features.
This includes forum, social and email sites.
Your unique ID and password lets the site customize your experience on the website.
Google Chrome includes a password management function to save and retrieve your passwords.
Open your Google Chrome browser.
Click on the Wrench icon in the upper right corner of the screen and then click "Options."
Click the "Personal Stuff" tab in the Options window. Make sure that "Offer to save passwords" is checked.
Click the "Manage saved passwords" button to see the saved passwords.
Click the website from which you want to retrieve the password to select it.
Click the "Show Password" button to see the password.
Find a Password Using Regedit
If you have Windows set to log you on automatically, you can find the password for your user account by looking in the registry.
By entering the "regedit" command, you can access the Registry Editor and view the password. Keep in mind, however, that this only works if you have Windows set to log you in automatically.
Click the "Start" button and choose the "Run" option.
Type "regedit" and click "OK."
Navigate to "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon."
Look at the "DefaultPassword" line to view the password.
Aug 08, 2013 | Computers & Internet
How to recover password
Mac Instructions
Hope this helps.
Jul 14, 2013 | Computers & Internet
I need to know how to do a password reset ..i am locked out of the computer. it is asking for a password and i do not know the password
Just hit the set up key as your machineboots up, usually, F2-F3 or F8. Go to safe mode using the up-down arrowsand where it says set/change password, simply hit the enter button, enter a newpassword in and close, using the save function. You can now use that new password and arenow officially the administrator! Or else, you need some Windows passwordreset program to help you do that job.
Nov 29, 2010 | Toshiba Computers & Internet
Boot up says op not found...boot up with drive
Hello, Sounds like your BIOS is password protected. Depending on what type of computer you have there is software that might be able to help you retrieve the password.
Good luck, mpawlak908.
Oct 19, 2009 | Sony VAIO GRX520 Notebook
How to reboot a verifone 3730 ommni
Hit the F2 and F4 button on the top right of your terminal.
Password is 1 ALPHA ALPHA 66831.
Then choose F4 restart.
Thats all.
www.greenlightpayments.com
May 06, 2009 | VeriFone Omni 3700
Bios-Password
When you hit F2 there may be an option to clear this password. If it is not or it is locked (by a password), you will need to call Toshiba or an authorized service provider.
Passwords on portable computers are often secured so they cannot be reset unless you have the manufacturer's security tools to do so.
Hope this helps
Feb 01, 2009 | Microsoft Windows Vista Home Premium with...
E-Machines eMachines Desktop PC Logo
256 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
