Question about Whirlpool Dishwashers
Whirlpool gold, quiet partner III, My dishwasher is not cleaning very well and when it is done it flashes clean. The clean flashing light wont stop. It flashes 7 times and stops for 3 sec then starts again. I know how to reset washer using heated dry and normal buttons but when i run it again when it is finished it goes back to the clean button flashing
SOURCE: whirlpool gold- quiet partner III
I had a similar problem. So I bought a new computer for it. It didn't fix the problem. It turned out to be the button pannel. With all of moisture surrounding it steam go into the buttons and caused all kinds of faulse info that the computer could not interpt. Had to buy new button pannel and problem was fixed.
Posted on Mar 29, 2008
  • 14 Answers
SOURCE: Whirlpool Gold quiet partner III, leaves dirty, greasy dishes
Ifixall is correct. I also learned several things with the apartment buildings I maintain.
1. the screen or pump trap must also be cleaned regularly to make sure there is no debris, food etc stuck in there.
2. The spray arms must be free of debris or obstructions.
3. Jet dry solution must be filled or has some solution in it.
4. Water must be hot
5. Scraping dishes and prewash them before putting them into dishwasher.
6 install water softner sometimes helps. (I don't know how true this is, since I am unable to do this in our buildings)
7 drain line must be picked up, or secured to prevent backwash.
8. MAKE sure that the lower rack is not obstructing the sprayer arms. Sometimes overloading dishwashers will cause dishes not being cleaned properly.
9. if all else fails, a service technician can come out to determine if the dishwasher is operating properly.
Posted on May 24, 2008
WRMtech
  • 70 Answers
SOURCE: RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Posted on Mar 22, 2009
SOURCE: Cannot unscrew cap on rinse aid compartment in door of Whirlpool Gold Quiet Partner III
the cap doesn't come off, you just have to open the door all the way. then, when you pour the rinse aid into the dial area, it will get sucked into the dispenser. but if the door isn't open all the way it won't go anywhere and will overflow on you.
Posted on Nov 17, 2009
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Dishwasher won't reset, stays on gree-flashing light- Clean cycle
HI,
This is an indication that the water did not heat properly. I have put together some instructions on what can cause this and how to reset the control so you can use the dishwasher again. Follow the link below and let me know if this helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 10, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool Quiet Partner V light flashing
most of the time this meens your heat element is burnt out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 25, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
The only number on the nameplate of my Costco-purchased "Quiet Partner IV" built-in Whirlpool dishwasher (steel insides) is 8575637. This dishwasher does not clean spoons right-they always have dirt left...
Yes, you almost certainly have a Whirlpool Gold Quiet Partner III Model #8575637
Of course the great news with buying from Costco is the ability to return products you are dissatisfied with. Check with the customer service desk.
Please reply if you want to to get into repairing it and we will get under way.
Mar 31, 2009 | Whirlpool Gold 24" Tall Tub Built-In...
Clean light flashing Quiet Partner V
do the heated dry and hi temp and then hitr cancel. you know what this means?! you have a bad heating element usually. call for service this should be a covered repair if it is only 6 months old
Mar 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 | Dishwashers
Dishwashers Logo
117 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
