Question about Olympus DS-2200 Handheld Digital Voice Recorder
I can't get my OlympusDS-2200 to set Time/Date. Since this is the first step, the prospects don't look good.
    Genius:
  • 1,218 Answers
I am assuming you don't have the instructions...go to www.olypusamerica.com to download instruction manual.
Posted on Oct 02, 2010
I HAVE a reboot notice: TAMPERINg detected 04008. REBOOT
you will need to see if you can change the date in the terminal if you can then it will bypass this error if you can not you will need to replace your machine.
Step 1: Select GREEN ENTER key
Step 2: Select the PURPLE MORE key
Step 3: Select SET UP
Step 4: Type in your password if applicable (1 Alpha Aplha 66831)
Step 5: Select the PURPLE MORE key until the display reads SET DATE/TIME
Step 6: Select SET DATE/TIME
Step 7: Enter the correct date (MM/DD/YYYY)
Step 8: Enter the correct time (military time) (HHMMSS) Select ENTER
Step 9: Select the RED CANCEL key
OR
Step 1: Select F2/F4 at the same time
Step 2: Type in your password if applicable (1 Alpha Aplha 66831)
Step 3: Select the PURPLE MORE key
Step 4: Select CLOCK
Step 5: Select EDIT
Oct 22, 2014 | VeriFone Omni VX-510 Credit Card Machine...
How to set the clock
Dear,
Please follow the below steps
Step 1: Towards the bottom of the screen you'll see 'Date and Time'. Tap that. You may need to scroll down to get to Date and Time as it is at the end of the list.
Step 2: Tap Set time and then use the scrollers to set the time. Tap Set date and then use the scrollers to set the date. In both cases tap Set when you are done.
Regards,
Samy
reg
Aug 10, 2014 | Polaroid Tablets & eReaders
How can i get to date and time screen on nikon coolpix s4000?
The attached file will give you a copy of the S4000 manual. Go to pages 22 and 23 for step-by-step instructions. http://cdn-10.nikon-cdn.com/pdf/manuals/kie88335f7869dfuejdl=-cww2/S4000_EN.pdf
Jun 02, 2014 | Nikon Coolpix 2200 Digital Camera
I can't figure out how to set the time and date on the HEM7300REL blood pressure monitor. I have a manual and have followed the instructions without results. I don't see a reset hold on the machine. do...
If you remove and replace your batteries...you will not lose the memory. The unit will store up to 90 measurements in non-volatile memory...so it will stay there.
I have the same unit and use these directions....and never had issues with setting the date and time.
2.2
Setting the Date and Time
Your blood pressure monitor automatically stores up to 90
measurements values with the date and time. To make use of the
memory and average values functions:
• Set the unit to the correct date and time before taking a measurement
for the first time.
• If the batteries have been removed for more than 30 seconds, the
Date/Time setting will need to be set.
1. Press and hold the Date/time
setting button (
) to adjust the
date and time. The year digits
(2008) will flash on the display.
2. Press the Memory button ( ) to
advance the digits one at a time.
Notes:
• The range for the year setting is
2008 to 2030. If the year
reaches 2030, it will return to
2008.
• If you hold down the Memory
button ( ), the digits will
advance rapidly.
3.
Press the Date/time setting
button (
) to confirm the setting
when the desired number
appears on the display.
The year is set and the month
digits flash on the display.
4.
Repeat steps 2 and 3 to set the
month.
The month is set and the day
5.
day.
The day is set and the hour digits
6.
hour.
The hour is set and the minutes
7.
minutes.
The minutes settings is set.
button (
) to turn the monitor
off.
When adjusting the date and
time, press the Date/time setting
button (
on, follow the steps above, and press the START/STOP
button to turn the monitor off.
Good luck.
Semper Fi,
Z
Jan 31, 2018 | Omron HEM-780N2 Automatic Blood Pressure...
Hi, I have an nikon coolpix s710...after I set date and time, when I turn off and start again, it ask me if I want to set date and time...please help me to fix this problem because when i start the camera...
1. In Set Up you must select the language you want to use by highlighting it then PRESS OK. If you don't do this then the date/time will not set.
2. When asked to set date and time you must select YES and press OK.
3. After completing each step you must press OK.
4. In the final step you must choose your preferred day/month/year display and then press OK.
If you don't press the OK button at each step the date and time will not set.
Aug 17, 2011 | Nikon COOLPIX S710 Digital Camera
I don`t know how to change the date and time of my sony dsc-t200
Hello there. You can do it this way:
1 Select (Clock Settings) from (Settings) on the HOME screen. 2 Touch [Clock Settings]. 3 Touch the desired date display format, then touch [t]. The clock settings screen appears. 4 Touch each item, then set its numeric value by touching v/V. 5 Touch [OK]. To cancel the clock setting Touch [Cancel] or [BACK] in step 5.
Sincerely, Steve TM
May 28, 2011 | Sony Cybershot DSC-T200 Digital Camera
Have never set date on my camera. What do I need to do to accomplish this? Do I needsoft ware, any cords, etc? Tried to go by instructions on line but it didn't work. What am I missing? Thanks
Welcome to FixYa,
Hi I have here the steps on how you can update the date and time of your digital camera. You can chaged it if its your first time to set the date and then you also have here the steps if you want to changed it anytime you want.
Setting the date & time, first time
The Date and Time have been reset message appears the first time you turn on
the camera or if the batteries are removed for an extended time.
1 SET DATE & TIME is highlighted. Press the OK button.
(Select Cancel to set the date and time at a later time.)
2 Go to step 4 below, Setting the date & time, anytime.
1 Turn on the camera. Press the Menu button.
2 Press to highlight Setup Menu , then press the OK button.
3 Press to highlight Date & Time , then press the OK button.
4 Press to adjust the date and time. Press to advance to the next
setting.
5 When finished, press the OK button.
6 Press the Menu button to exit the menu.
Reminders:Depending on your computer operating system, Kodak EasyShare software may let your computer update the camera clock when you connect the camera.
I hope this steps will let you to resolved your issue.
Feel free to reply on this e-mail if this steps will work or won't work.
Thank you for using FixYa.
Mar 23, 2011 | Kodak EasyShare CX7330 Digital Camera
How do you set the time and date?
Step 1.
Press the PROGRAM button, then press * * 1 2 3 4
The display should now read: USR-PGM NO?
Step 2.
Enter: 0 0 0
Display: Day/Time Set
Step 3.
Press NEXT (or the SPKR PHN button)
Display: shows date (if you need to change the date, see steps 5 thru. 10 below)
Step 4.
Press NEXT (or the SPKR PHN button) again
Display: shows time example: 12:00 AM
Step 5.
Enter the hour
to change current entry, press CLEAR (or the TRANSFER button)
Step 6.
Press --> (or FWD/DND button)
Step 7.
Enter the minutes
Step 8.
Step 9.
Press SEL (or AUTO ANSWER/MUTE button) to change AM or PM
Step 10.
Press STORE (or AUTO DIAL/STORE) - Don’t forget this step!
Step 11.
Press END (or HOLD button)
Step 12.
Press SPKR PHN button or pick up and hang up the phone to leave programming mode.
Dec 20, 2008 | Panasonic KX-T7731 Corded Phone
I have Canon Multipass fax C2500 Have misplaced instruction book Please advise how I can reset the date and time Thank-you Don Walter- E.F.Walter Incdonwalter@sympatico.ca
The manual is available for download here. (It takes a while to show up, as it is a large manual.) Step by step instructions for setting up date, time, and other user settings in Chapter 3.
Apr 18, 2008 | Office Equipment & Supplies
Time/Date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display1.gif will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Feb 20, 2008 | Sharp EL-2630P Calculator
Olympus DS-2200 Handheld Digital Voice Recorder Logo
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
