Question about Leviton Electrical Supplies
I have a Leviton 5634 two rocker switch that I'm using to replace an old double switch that controls two lights. There are 1 black, 1 red, and 1 white wire in the light switch box. The white wire is currently spliced to connect to a terminal of each of the swiches (the existing swich actully has two distinct switches put together). One of the switches has the red wire connected to the opposite side from the white and the other switch has the black wire connected to the opposide side from the white. How do I connect the existing wires to the new switch? Thanks for your help!
Review old switches:
Two old switches > each has 2 wires
Old switch 1 > Red and White
Old switch 2 > Black and White
The same white wire connects to both switches, so effectively they count as 1 wire
This means you have 3 wires ... 1 White, 1 Red, 1 Black
Each switch controls a separate load (light, fan, motor)
New Leviton double-rocker switch:
-Leviton has 2 Brass-colored screws on one side, and these screws are connected together by a brass plate >> your Hot wire will connect to brass screw
-Leviton has 2 Silver-colored screws on other side, and neither of these screws are connected in any way >> the wires going to each load will connect on a different screw on this side of switch.
Hot wire: Each box in your house has exactly 1 hot wire that is connected back to breaker box. This is true for all boxes (excluding boxes that have a 3-way & 4-way switches).
We need to identify Hot wire.
-By code the Hot wire is black for identification purposes ... but your box sounds like maybe the Hot wire is White.
-If your Hot wire is white, that is NOT an immediate safety issue ... it will not cause a fire or malfunction ... it is a code violation ... because code requires things be uniform so next electrician knows what previous guy did. So some day, electrician working outside grabs wrong color wire, and wow. I say this so you know.
Moving on.
Identify Hot wire:
-Pull 3 wires up so they can be tested
-Turn on power
-Use ordinary tester, or old lamp with plug cut off and wires stripped back
-Tape tester lead to sticks so hands are away from voltage
-Power is on. Don't stand in water or touch metal pipes, and you're fine.
-You have 3 wires in box + ground wire
-Test all 3 wires to bare ground wire >> when tester lights up, that is Hot wire ... testing is complete
Connect wires to Leviton double-rocker:
-Power is OFF.
-You have 3 wires - 1 White, 1 Black, 1 Red >> one is Hot wire, the other two wires go to load
-Hot wire connects to Brass-colored screws on new Leviton.
-Brass colored screws are connected together by a brass plate so the Hot does not need to connect to both brass screws.
-The other two wires connect to Silver screws on other side of new Leviton switch
-One wire goes to each silver screw
-Connect bare ground wire to green screw.
-Push wires back into box. Use eraser end of pencil if needed.
-Make sure ground wire is back and away from screws on switch
-That's it.
Posted on Sep 30, 2010
How to wire a leviton 5634 for agarbage disposal
If you are replacing an existing switch, either replace one wire at a time, or write down the wire colors from the old switch.
or look here: http://www.leviton.com/OA_HTML/LevitonSearchResults.jsp?kw=5634+wiring+diagram&tbon=D
May 16, 2014 | Leviton R03-5634-A Two Single-pole...
I have a leviton double switch that i can't get to work. I have 3 white and 3 black in the box
Try the link below for a diagram.
I would think that you have one black feed and two black legs going out, and three common wires that should be wired together with a wire nut. Is this for a ceiling fan with a light? or ?
May 14, 2014 | Leviton 5634 Dual 1 Pole Switch Decora...
Light switch
Try to switch the white with the black wire
Apr 16, 2014 | Leviton 5634 Dual 1 Pole Switch Decora...
Replaing old double switch with two black and one red wire with new leviton double switch. For two light sources. help!
1) More information is needed about switch that is being replaced, and model number of new switch, and what you want to do, and what each wire goes to.
http://waterheatertimer.org/How-to-wire-switches.html#double
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 10, 2013 | Electrical Supplies
How to connect leviton 5634 from GFI
GFCI device is not identified.
Leviton 5634 is typical double switch.
Open following link for image showing double switch connected to typical GFCI outlet.
http://waterheatertimer.org/How-to-wire-GFCI.html
Add a comment with details about your wiring and GFCI for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 09, 2011 | Leviton 5634 Dual 1 Pole Switch Decora...
Trying to install this thing, and having a slight issue. I've got a white, black and red line power line in the bathroom, obviously.. I've also got a dual switch Leviton 5634 which I'm just trying to...
I assume these three wires are coming to the switch box via from the light/fan unit and the light/fan unit has a box with 5 wires in it, including a white and black from the electric panel, and that the neutral is not routed to your switch box. I think your mistake is assuming that the black wire in the switch box is the hot wire, but it is actually the red or the white. Try switching the wires on your switch so that the red is common, If that doesn't work, try the white as common. Or you might open the box where the fan is, and confirm which of your three wires is connected to the hot black wire. Please vote if you found this helpful.
Good luck, Al K
Feb 24, 2011 | Leviton 5634 Dual 1 Pole Switch Decora...
I have the unit wired and it does not wotk.I have black to black,red to red green to ground and white to white,any thoughts? Thank you
Electrician test wiring before connecting anything.
First of all, you don't mention what type of switch was replaced.
1) Leviton 6230 countdown timer is made to replace single-pole light switch only.
Single pole is where 1 switch controls the Load (light fan motor)
Your wiring sounds like 3-way switch.
3-way is where 2 switches control same Load.
For example a hallway usually has 3-way switches.
To confirm. If old switch has 1 dark screw, 2 brass screws, and 1 green screw, then that is 3-way switch. Use Leviton LTB15, LTB30, LTB60, LTB02, LTB12 countdown timer for 3-way.
Smarthome sells product and shows .pdf manual
http://www.smarthome.com/4255/Leviton-LTB60-1LZ-4-Button-10-20-30-60-Minute-Countdown-Timer-Switch/p.aspx
2) If old switch has 2 brass screws and 1 green screw then that is single-pole switch.
3) If you are replacing single-pole switch, here are testing & wiring instructions for Leviton timer.
Remove device and separate wires for testing.
Use ordinary two wire tester.
Tape tester leads to wood sticks so hands are away from power.
Do not untwist wires that were twisted together before you started.
Turn on power.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire will connect to timer black wire.
Now you know Hot wire.
Test Hot wire to each of the other wires, excluding bare ground wire.
Tester lights up on neutral. Timer white wire connects to Neutral wire.
If box does not contain Neutral wire, then timer white wire connects to bare ground.
Timer green wire connects to bare ground wire.
Timer red wire connects to wire going to Load.
Dec 26, 2010 | Leviton 6230M Decora Four Preset...
I'm using a Leviton 1755 combo 3 switch for a bath light/fan combo and then onto a vanity light. Basics: wires from ceiling light/fan: black, red, white, ground. Wires to vanity light: black, white,...
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Feb 22, 2010 | Leviton 003-1755-W Three Rocker Switches
I am replacing a single pole switch that contains two rockers - one controls some lights, the other the garbage disposal. I am using a Levitron 5634; when I removed the broken switch it had 3 wires...
You have the hot wire on the wrong side of the switch. The side of the switch with the fin is where you put the hot wire. On the other side of the switch where there is no fin is where you put the other two wires one on each screw. When you have it wired that wat your switch will work like the old one. Also if you would like the lights to come on with the top part of switch. But works with the bottom switch you just need to switch the two wires from top to bottom.
Jan 20, 2010 | Leviton COMBINATION SINGLE POLE TOGGLE...
Electrical Supplies Logo
758 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
