Question about Philips GoGear SA3245/37 Digital Media Player
I need video conventer philips - Philips GoGear SA3245/37 Digital Media Player
  • 27 Answers
Philips smart tv
If your sound system has an optical input, then use the TVs optical out socket and connect the two.
If the sound system just red & white phono/RCA sockets, or a 3.5mm jack then you need an optical to RCA convertor box. This will change digital into something that a conventional sound system can understand.
Here's the right type of box from Amazon
Sep 03, 2014 | Philips 40pfl4706/f7 40 Lcd Hdtv 1080p Led...
Screw driver type for Phillips MMS 203/17
Its called a torks (spelling not correct) and usually a #10 or smaller, you can buy a set of 5 or more for under 20 dollars at home depot and most hardware stores sell the larger ones---
A set of the smaller ones is handy for a lot of things including cell phones and devices that are small----Philips started all this, going from conventional to torks----Had several Philips Plasma sets with over 50 to remove to just take the cover off.
Dec 13, 2012 | Philips MMS 203 Computer Speakers
Can Intel DG41TY Motherboard Suppotrs PCI-- Exress 2.0 Video Cards???
This motherboard has 4 expansion slots and these are -
1. PCI Conventional bus add-in card connector
2. PCI Conventional bus add-in card connector
3. PCI Express x1 connector (this is a short connector)
4. PCI Express x16 connector (this is a long connector)
Use this information and ask the supplier for suitable video cards.
You need to also tell them what video applications you are using eg. games that require high end video cards. These video games also recommend types of video cards suitable for these games.
Mar 09, 2012 | Intel Computers & Internet
Cannot find power adapter for mms171w philips system. Needs AC/AC adapter with 10v ac at 1.8 amps output. Cannot find aftermarket counterpart either. Help. Lost adapter while moving.
What does the other end of the adapter look like?
Is it a conventional circular one or is it a special port like it's thin square like or USB like maybe?
If it's conventional any 10v 1.8amp or 2 amp output should do and a lot of them are available in e-bay or if there's a Best Buy, Staples, Etc near you can just drop a visit purchase one and it should work like a charm.
However if it's not a conventional adapter you may have to contact philips and purchase one that is compatible from them.
Hope this shed some light on your problem!
May 31, 2011 | Philips MMS171 Computer Speakers
I'm just wondering what type of video file does the go vibe mp3 player use.
This player uses SMV video files, which are common in low cost video players.
An SMV file is composed of three sections, concatenated together:
  1. A .wav file for the audio stream, with a conventional WAV header.
  2. An SMV header, described below.
  3. An array of .jpeg files for the video stream, with headers, each prepended by a 24-bit (3 byte) little-endian value representing the size of the image and buffered at the end with nulls.
May 05, 2011 | Philips GoGear ViBE Digital Media Player
My philips lcd tv has sound but no picture what is
change the backlight (cold cathode light) on your monitor.. If you are able to open the back of your lcd monitor carefully, the backlights are located at the upper and the lower part of the edge .. replace it with conventional cold cathode lights(protective tube was removed)... there are also instances that backlight was good but the ballast transformer is burnt. Replace the ballast. Its very cheap to replace that.
May 18, 2010 | Philips 42PFL7432D 42 in. LCD Television
Blank display on the Monitor when connected to main system
if u feel the problem with you display cable then try to replace that
May 12, 2010 | Philips 107E56 17" CRT Monitor
How do i get codes to program a universal remote to this tv
This will require you have the newer remote to program this TV. The conventional ones purchased at discount stores rarely have these. Contact the Philips company about puchasing a universal remote. Emerson is under contract with Philips now!
Jan 10, 2010 | Emerson SLC195EM8 LCD TV
Carnt watch videos on my gogear mp4 player
When in doubt, do what the message says.
You have to use the Philips (Arcsoft) Media Converter to convert/transfer videos. If the converter is not recognizing a specific video type - FLV, for instance - download a free program called Riva FLV Encoder and convert the videos to AVI format first. Then the Philips Media Converter will recognize them.
The Philips Media Converter is not capable of converting an entire DVD - you will have to acquire video editing software, and then break up the DVD files into 15-minute chunks, and then convert each chunk.
If you are getting a codec error, do a google search for free video codecs - they are out there. Windows Codec Pack and downloading the latest version of quicktime will give you most of these needed codecs.
This player is not capable of playing copyright-protected videos - so don't even bother with them.
Additional information is available both from Philips website and from Arcsoft's website.
-Tha Mp3 Doctor
Feb 26, 2009 | Philips GoGear Flash MP3 Player
Not displaying
most probably it is power supply problem & if it is ok check hor. section. good luck
Mar 26, 2007 | Philips 107B55 (Black) 17 in.CRT...
Philips GoGear SA3245/37  Digital Media Player Logo
24 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
