Question about Protron PD-DVR100 DVD Recorder
Can't get this unit to power on at all. It just suddenly shut off one day, and I don't get ANYTHING on the display. I pulled the IDE drive (Philips D4.2...Philips doesn't know anything about it) and put it in a desktop...THAT works fine still. The power supply in the unit emits a high-pitched whining when it's plugged in. The part number on the supply is 071-00829-R0007 Rev:00 Anyone know where I can get a new power supply for this?
3 Suggested Answers
SOURCE: Blackout, High Pitch Squeel
Funny to see this because this is exactly what is happening to my 32 inch TV and I was researching to see if some one else had this problem and right away I find this, I've had my set for over a year now, and I have no solution at this time, but I will continue to research this, I figured that Protron would blame the cable company,that's what company's with crappy products usually do. Blame someone else.
Posted on Jun 03, 2007
  • 2318 Answers
SOURCE: Does anyone know which connector to plug into on power supply
Double check all the connections from the AC line and from the power supply to the other circuit boards. The connectors you are mentioning are identical as per the picture below.
If you need a new power supply, you can find one from this link.
Posted on Dec 04, 2009
Testimonial: "I have a few more questions that I would love to ask Jaime867. He produced a drawing of my circuit board within minutes and was a big help. Thanks"
Philips htl2100/12 soundbar doesnt respond to remote control after plugging in
My soundbar won't power up. So I pull the battery out of remote, press a few buttons, put the battery back in and all of a sudden the device can be powered up and controlled. Until next time it stops responding. I replaced that original battery with a new one but the problem still persists.
Dec 10, 2013 | Philips SoundBar DVD Home Theater with...
Maxtor hard drive settings for a 53073H4
Before doing anything, the user should completely shut down and unplug the computer to prevent electrocution or computer damage. Remove the computer's side panel so that the hard drive is displayed in order to find the jumpers on the IDE drive. Disconnect the power and IDE cables from the hard drive to access the drive better. The hard drive's jumpers are the small, black pegs on the back of the drive. These pegs fit over small metal conductors and assign the IDE drive's role. The user can remove the jumpers by prying them off of their current conductors with his/her fingernails or a small screwdriver. The jumpers can then be relocated to other conductors in order to assign a role to the IDE drive. The user should be very careful while handling the Maxtor jumpers as they are fragile and very important.maxtor-jumper-settings.jpegEach IDE drive model is different but most have three basic settings: Cable Select, Master, and Slave. Each setting is described below.
Cable Select
Cable Select is a Maxtor jumper setting that is the default for virtually all IDE drives. Cable Select allows an IDE drive to naturally become either a Master or Slave depending on the cable used. Cable Select is a neutral setting and is also often used when a user only has one IDE device installed or when a device is neither a Master or a Slave, such as a Floppy Disk drive.
hope this helps
Jun 22, 2012 | Maxtor Hard Drive
How do you install an hd204ui
this will depend on HARD DRIVE whether ide the ide will have 40 pins or sata the sata will have 8 copper slat type also PSU power supply unit ide or sata power connecters these days they usually supply both next MOTHERBOARD if has ide and sata plugs the ide will be a flat ribbon type with 40 pin plug ends the sata will be 8 copper slat type usually a bit thicker
hope this helps
molex to power sata converters
ide lead which will locate itself by the blank
http://www.amazon.com/gp/customer-media/product-gallery/B0001Y8UI4/ref=cm_ciu_pdp_images_all
molex 4 pin power lead
hope this helps
Jun 23, 2011 | Samsung Computers & Internet
I replaced the power supply but not sure I have all the connections correct. Don't want to plug it in until I get it correct, is there a diagram of where the plugs go?
hope this helps
Jun 09, 2011 | Computers & Internet
I want buying the extension of lace hard drive 160 g between the adapter and the hard drive.
hope this helps
May 27, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
I have a problem with my JVC KD-R600. The radio turns on and then it shuts off the display and it won't do anything else. It takes CDs and it would display that is loading but then it will shut off. If I...
Hi have you solved this problem as I am now experiencing the dame problem after I havnt used the unit for some time now and installed into a different car and I am experiencing the same problem as you have mentioned
May 28, 2010 | JVC KD-R600 Car CD/ MP3 Player
USB support suddenly not working
I have a similar problem and got it to work by resetting the player to the initial settings.
To do this, turn the player off. On the front panel
Hold down the STOP button and turn the player back on.
Display will show CLEAR.
You will have to reenter your settings, but it recognizes the USB again.
I just got this to work, so who knows how long it will last.
Nov 02, 2008 | Pioneer DV410V DVD Player
Protection displayed and shuts off
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
Mar 01, 2008 | Samsung HT-X40 System
Will not charge
If the battery is dead as in not recoverable you may get this problem .
You could try another 5v charger in case yours is Duff
Phillips have responded well in the past so a visit to their site may help
Oct 19, 2007 | Philips HDD120 MP3 Player
Protron PD-DVR100 DVD Recorder Logo
53 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
