Question about Whirlpool Refrigerators
Compressor working continuously but no cooling effect
    Brigadier General:
  • 3,513 Answers
Please check the bellow links to trouble shoot your problem. Since the compressor is running as you said but the unit is not getting cold then there must be something related to frost built up in evaporator coil or the evaporator fan is not working. There are many reasons that causes such problem to your unit. Kindly go through the links bellow to have a detailed idea:-
http://www.applianceaid.com/frig_notcold.html
http://www.repairclinic.com/Refrigerator-Troubleshooting#Itsnotcool
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 30, 2010
1998 GT22DKXGN00 refrigerator freezes, where is thermostat in refrigerator ? This is a Whirlpool
Check refrigerator and freezer temperature. If the freezer is above 0 degrees Fahrenheit it is likely the cooling capacity of the unit has reduced due to low charge or weak compressor. What usually happens is that the freezer is not able to reach the proper temperature and the unit runs continuously. The result is that the refrigerator via the freezer-refrigerator air flow connection freezes.
"This is not intuitive", but the logic is that from the compressor running continuously the freezing air that flows into the refrigerator side results in that the refrigerator will freeze,.
Check the temperatures. If the freezer is above 10 degrees F it is almost certianty the cooling capacity has been reduced.
If equipped with an ice maker the output of the ice-maker will also reduce with this problem
It is possible to have the compressor replaced but not usually cost effective.
Apr 10, 2017 | Refrigerators
Aircon is only blowing ambient air with no cooling effect. the indoor and out door unit appear to be operating normally. am I out of gas or is the compressor not running? what could cause this to suddenly...
First of all check your compressor is working with correct amps. If yes, service your unit to improve better cooling. If compressor not working find out the root cause for it. Please call repairman to find the fault.
We can only give solution by having particular cause or error code is stated by you.
And also follow these tips always:
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 16, 2011 | Fujitsu 18C1 Air Conditioner
My refrigerator and freezer will work fine for a day or so, and then cool poorly. The compressor runs continually when it cools poorly. If I unplug it and plug it back in a few seconds later it will run...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 30, 2010 | GE Refrigerators
FR23SL Uses Peltier Cooling - No compressor nor freon....
Luzer - Thanks for the very helpful solution. My cooler has the problem described. When I take off the back and plug it back in, all three fans run, but the unit does not get cold. Is it possible that it needs new fans anyway (like maybe they are going but not moving enough air to generate the effect)? Or woudl it be something else?
Thanks!
Mar 25, 2010 | Emerson (025806803716) Wine Cooler
Refer warming / no compressor / no fan
If the fan doesn't work , the compressor overheats and shut off by the overload protection.I would replace the fan which will cost no more than $30.
Sep 19, 2009 | Refrigerators
DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
May 31, 2009 | Dometic Rooftop RV Air Conditioner
Will run and cool until the thermostat turns it off and will not start back up. Inside fan continues to run. Compressor is completely dead.
Dear jack289,
The thermostat is not working properly. When thermostat cutsoff the compressor Please turn the thermostat knob to higher setting if compressor starts working then please change the thermostat. The fan will run continuously since only the compressor is controlled by the themostat.
Regards,
ramesh22
Jun 25, 2008 | Intertherm Heating & Cooling
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
