Question about Saeco Aroma Espresso Machine
I have a saeco aroma expresso machine and it brew fine but when I put the pod adaptor in (followed manual) it leaks very badly. I took out the double and first put black rubber adaptor with bowl shape facing up so it receives liquid. then I put silver one cup on top but it doesn't truly fit and this is probably why it leaks. I am using ESE lavazza pods. Could it be I was sent wrong adaptor?
SOURCE: Saeco Vienna superautomatica Machine
if you open the steamer, does it work correctly? and if u request hot water does it come out?
if not, then its the pump..
Posted on Dec 30, 2007
dutchman05
  • 487 Answers
SOURCE: Our Saeco Incanto coffee machine
mmmm ormally with turning off and on it should reset itself.
Posted on Apr 16, 2008
  • 40 Answers
SOURCE: Saeco Vienna Digital Expresso Maker - brew group will not line up to fit back into espresso machine
Could be a number of reasons. If you "hear" the brew group moving in one direction, stop and then move again, then the microswitches are o.k. If the sound of the movement is low and/or slow ( slower that normal), the CPU/power board may be bad and needs to be replace. If the movement is as before (same sound and movement) but not lining up, perhaps the brew drive motor is bad.
To remedy this situation, an authorized SAECO Service Center would have to open your machine and replace damaged components. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
mirran
  • 515 Answers
SOURCE: My Saeco Aroma Expresso machine has water leaks
I think you have to replace the gasket in the machine where the portafiller fits on the machine.
Make sure your filter is clean before you replace any gasket.
/Mirran
Posted on Aug 23, 2008
SOURCE: Saeco Aroma now only produce bitter coffee...
besides a good coffee machine, 2 things are critical when you want a good cup of coffee; the coffee itself and the water. When in France, i tasted some of the best coffee I have ever had, but they always told me that the quality and purity of the water made for 50% of that great taste. Has your municipality changed anything about the water treatment recently? Do you drink that same water and find it tastes funny? Perhaps bottled water is a solution in your case. Hoping this helps.
Marc
Posted on Feb 04, 2009
Hi,I just bought a Aroma Saeco Manual Expresso machine from Amazon.
make your concerns known directly to amazon and if they will not assist then return it for a refund as it is not fit for the purpose
Feb 07, 2016 | Saeco Aroma - Stainless-Steel
The brew group is stuck half way thru the brew cycle and now it won't finish making or dispensing steam. How can I unstick the group?
Hello Teresa,
I understand that the brew group is stuck in your Expresso Machine. Did you know that it has to be removed and cleaned ever so often. The users manual explains how to reset and remove it for cleaning. Incase you no longer have the users manual here is a link to the users manual http://www.cerinicoffee.com/custompages/Manuals/Saeco/IncantoClassic_Manual.pdf
Thank you for using FixYa.com
Justin
Mar 11, 2011 | Saeco Incanto Classic Espresso Machine
The steam light on my Saeco Aroma does not turn on (and no steam comes out), even after the brew light turns on and I press the steam button. How can I get my steam to work?
HI
It is probably your steam thermostat that needs to be replaced. There are 2 thermostats. The Brew and steam. If one of them fail it won't heat the boiler for that mode. They are easy to replace.
Oct 05, 2010 | Saeco Aroma Espresso Machine
Cannot release the brew group for, saeco
Group is stuck in mid cycle due to some obstruction. You will need to have it serviced. Though it's possible to jiggle and pull it out. The machine will not likely reset itself, preventing you from re-inserting the group. Still requires a service to manually remove obstruction and reset it.
Feb 08, 2010 | Saeco Odea Go
Hello. I have had my Incanto Sirius S-Series for
check your brew valve,maybe is plugged or leaking in tray.
Sep 03, 2009 | Saeco Incanto Sirius Fully Automatic...
/Mirran
Aug 22, 2008 | Saeco Aroma Espresso Machine
Feb 18, 2008 | Saeco Vienna Digital Coffee Maker,...
Coffee Makers & Espresso Machines Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
