Question about Cameras
My camera comes on the turns right back off and makes a sound when its turning off battery is charged
    Brigadier General:
  • 3,006 Answers
Your camera almost certainly has a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the camera manufacturer's service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 30, 2010
My camera turns on then turns right back off again?
Same thing happened to mine, and it had to be sent away for repairs.
May 07, 2017 | Kodak EASYSHARE M763 Digital Camera
Its charged. i turn it on and it chuts right back
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 14, 2009 | Kodak EASYSHARE M1063 Digital Camera
Can't get the camera to turn on.
It sounds like a repair, therefor I have attached the KODAK contact at the end of the this solution. But before you call, here are a few steps you can try, I hope it will work.
Dec 07, 2009 | Kodak Easyshare M753 Digital Camera
My camera turns on then turns back off right away!
Hi Most proberly the batery is shot. It wil be fully charged but it does not have "the amps" in this case miliamps to do the job. Pushing out the lens uses alot of the amps "miliamps" and the fact that it can't even rectract the lens back is a sure sign. If possible take the camera to a digital shop and test it with a known good batery!
Strongs
Aug 16, 2009 | Kodak EasyShare M863 Digital Camera
My camera turns on than turns right off
If your cam use AA batt.:
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Jun 05, 2009 | Kodak EasyShare Z885 Digital Camera
Casio ES770
Hi
Check the battery when battery is weak these problems will occur..If u have warranty means then claim it..
Normally the sound will come..
Sep 16, 2008 | Casio Exilim EXZ75 Digital Camera
Olympus FE-190
on the right side of the camera where the memory card goes in thats where it is usally loose it it does that. try not to touch the part that slides out when you take the pictures or turn it on and it will be back to normal.
Jul 08, 2008 | Olympus FE-190 Digital Camera
Cameras Logo
61 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
