Question about Siemens 24 in. SL84A302UC Built-in Dishwasher
The rinse agent light comes on, but wont turn off?
    Habit-Forming:
  • 84 Answers
Add rinse agent to the compartment beside where you put the detergent,a blue liquid
Posted on Sep 30, 2010
Can't select cycle and won't start.
you didn't mention the model number , but I can tell you some models wont start if there's no rinse agent in the dispenser , also for stuck controls a trick that works is to find the breaker for washer in your power panel and click it off for one minute then back on this will force a reset of controls
Jan 22, 2016 | Dishwashers
"add rinse agent" indicator light will not reset?
Switch the unit from mains to reset and try again
Jul 25, 2014 | Bosch Dishwashers
I have an Electrolux Dishwasher that always starts on low rinse
Hello Friend, this is Z. Thank you for your post!
I see that your Electrolux dishwasher starts cycle on low rinse. This typically indicates your dishwasher has low rinse aid. The RINISING AGENT LOW light, typically located near the Rinse Only Pad, comes on at the end of cleaning cycle when the rinse agent reservoir is low. The light will remain on through 5 successive cycles or until the reservoir is filled. Also, using rinse aid will enhance dryer performance and reduces water sports and filming. Hope this helps!
Jun 04, 2014 | Electrolux Dishwashers
I have Hobard LXIH dishwasher, it is working OK but during rinse cycle instead of taking in rinse agent it is actually fill rinse bottle back with water. Rinse pump is working, it was replaced in June
Check the rinse pump. The tubing needs to come from the supply into the bottom of the pump, and the pump should be running clockwise. If the pump tube is worn, the rinse pressure will blow through the pump filling the bottle
Dec 12, 2013 | Hobart Dishwashers
I have a Bosch SHE4AM15UC diswasher. The rinse agent comes out at the gasget. The rinse agent light does not come on anymore windicating it needs more agent.
I would have to say the sensor may be fouled up and need to be cleaned if you are concerned about the light. If the rinse agent is coming out of the gasket I would look for small cracks around the dispenser, then the door panel may need to be replaced.
Sep 06, 2012 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Hello, our Kenmore dishwasher's rinse agent dispenser is overflowing and won't empty. We haven't been able to add vinegar (all we have ever used in it) for a very long time. The dishes are definitely not...
Open the cap to the rinse despensor.
There is an arrow in the center that turns.
Turn it a click or 2 toward the dish washer bottom.
The more it faces the bottom the more rinse agent it will despense.
I hope this helps you....
Aug 08, 2010 | Dishwashers
The rinse agent light is on and the water will not spray out
NO WILL STILL WORK IS ONLY A FLOAT SWITCH TO WARN YOU,HOWEVER RINSE AGENT DOES AID THE DRYING PROCESS SO WITHOUT YOURE DISHES WILL BE WET AND SMEARY
Sep 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
PLD4555RFC: Low Rinse Agent Light Will Not Go Out
I've disconnected the sensor in the dispenser for my new Frigidaire dishwasher. The setup is too unreliable in my opinion and is a potential source of headaches. I had the same problem. I studied the design and it's too easy for the floating magnet sensor in the rinse aid reservoir to stick thereby not actuating what is called a reed switch to toggle the control card LO ckt light. Mine has the electronic control front panel.
Jan 07, 2008 | Frigidaire PLD4555RFC Dishwasher
Dishwashers Logo
165 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
